Projects Valve seal question
Discussion in 'The Hokey Ass Message Board' started by IowaTom, Sep 16, 2022.
  1. IowaTom
    IowaTom
    Guys - I'm rebuilding an old AMC 195.6 OHV inline six, hoping these Fel-Pro valve seals will be okay. What came in my NOS gasket kit (from the late 50s or early 60s) are the thin rubber umbrella type.
    This one pictured comes from a set of 12 I bought off ebarf. The stem diameter is the same as mine and I'd appreciate the input from smarter engine guys... are these okay for my old daily driver? Thanks!
  2. Jmountainjr
    Jmountainjr
    Nothing wrong with the original umbrella type seal. The one shown will provide a tighter seal. You said the stem diameter is the same. How about the ID that goes over the valve guide? Many of that type of seal require the valve guide to be cut with a special cutter before installation to keep it tight on the OD of the guide.
  3. MCjim
    MCjim
    from soCal
    I prefer these Teflon seals with the metal base...but this being the HAMB, it should stir up a controversy worth a couple pages.
  4. ClayMart
    ClayMart
    The regular rubber umbrella seals should work fine for an application like this, especially if it means you don't have to cut the O.D. of the guides to make them fit. Besides, you want at least a little bit of oil to find it's way to the valve stems.
    :rolleyes:
  5. onetrickpony
    onetrickpony
    from Texas
    IMHO, I prefer umbrella seals on the exhaust. The exhaust valves run hotter and a little extra lube helps cool them and just goes out the tailpipe. When I use positive seals, I only use them on the intake side.
    Your mileage may vary. :)
  6. jimmy six
    jimmy six
    I use the metal to metal on the guide type. Bought the tool from Comp Cams. Use on all 16 and couldn’t be happier. Took about 30 minutes a head for a V8 during ***embly with each measured for retainer clearance. Ford umbrella type let too much oil by and added to the valve build up.
    lowrd, Truckdoctor Andy and Budget36 like this.
  7. Budget36
    Budget36
    Are you referring to the tool to cut the guides for the positive seals? If so, I ***ume it has a pilot that goes on the guide itself. Question I have did you do it on a mill or drill press?
  8. MCjim
    MCjim
    from soCal
    I can't speak for Jimmy six, but I just ordered what fit my guides and valve stems, standard Comp Cam item...ABC
    Budget36 likes this.
  9. gimpyshotrods
    gimpyshotrods
    A cl***ic cutter has a nice long pilot, which makes it hard to do it wrong, even with a hand drill.
    The key is to prop up the head, so that the guide is vertical, and let the effect of gravity on the drill motor feed the tool. Force can introduce side-load.
    That said, valve seals are flexible, and can tolerate some slight misalignment. Just don't go nuts.
  10. 34 5W Paul
    34 5W Paul
    from Fresno CA
    I've used those in several engines on both intake and exhaust and have been happy with them. Includes a 4 cyl, straight six and a couple of V8s. All good, I recommend them.
    The black one below was OEM on a 32v V8 and after 180k miles they were allowing enough oil to get by the valve stems that after idling for one light cycle it was a smoke show just taking off across the intersection. You can see it got hogged out after all those miles and heat cycles. New red one on the left solved the problem and it now runs so clean it p***ed Kommiefornia smog tests.
  11. jimmy six
    jimmy six
    I used a 1/2” electric hand drill. I was carful not to remove anymore than necessary from the top of the guide. The engine had a stock lift cam and original rockers. gimpy showed the tool. I like metal to the guide metal and not the plastic style.
  12. Kan Kustom
    Kan Kustom
  13. squirrel
    I wonder what Tom ended up using?
    I just did a minor overhaul on a 196 Rambler engine, I put in the umbrella seals from the (new) gasket set, and it's fine. It had some rubber with teflon seals on the guides, but they were breaking up, either from age or? I think someone had installed them to try to make up for the rings not sealing any longer?
  14. Budget36
    Budget36
    Were the bosses made to accept them, or were that like that as made?
  15. squirrel
    they fit over stock guides
    gimpyshotrods likes this.
