Technical valve spring compression?
Discussion in 'The Hokey Ass Message Board' started by Joshua O'Rourke, Aug 31, 2024.
  1. leon bee
    leon bee
    Like said above by others, collect a few tools and lap the valves yourself. But before you start, come up with a plan to allow valves to go back in the same hole they came out of.
  2. Sharpone
    Sharpone
    Welcome to the HAMB
    Good question and great advice, IMHO a full blown rebuild is best however machine shop work is expensive. If your heads are in fair shape a simple valve lap and new seals will get you up and running. Sounds like your engine was running ok before you removed heads to fix oil leaks so a simple shade tree valve job will get you down the road for a while. I’ve done a few engine freshen jobs with good results. The only thing that I can add is if you go the simple route is:
    1. If you find anything way out of spec - repair to spec. Otherwise you will likely have a a complete failure in a short time
    2. At some point a complete rebuild will be in order, if you only drive a couple thousand miles a year your simple rebuild may last decades, at 20000 a year who knows.
    3. I have run a few engines without harden seats with no problems, again if you can afford to have harden seats installed that is best.
    Dan
    ekimneirbo, RodStRace and Budget36 like this.
  3. Budget36
    Budget36
    @Joshua O'Rourke , what’s your location? Maybe there’s a HAMB member with a valve refacer and seat grinder that needs a pizza or burger lunch nearby.
    RodStRace and Sharpone like this.
  4. Joshua O'Rourke
    Joshua O'Rourke
    no burning oil or smoking, just visible leaks after parking and lots of greases all over, which most of it ive cleaned but there's still some degreasing left. The advice is very helpful thank you!
    ekimneirbo and Sharpone like this.
  5. Joshua O'Rourke
    Joshua O'Rourke
    thanks for the advice I'm hoping to get a quote for the heads tomorrow. "Sounds like your engine was running ok before you removed heads to fix oil leaks" you'd be correct the only problem it every had was starting hot but ive read that may have been do to vapor lock since the car would stat first try on cold. and your right im only planning on driving it a couple thousand miles a year.
    ekimneirbo, RodStRace and Sharpone like this.
  6. Budget36
    Budget36
    @Sharpone , I too have run a 235(rebuilt in the early 60’s) no idea about seats.
    In the 90’s when I got it running and was a Daily for me for a few years. I bet I put 12-20k miles on it-no clue. Ran it at 3k, that was my speedometer;).
    Once fired up and running right, I did a hot running valve adjustment-anyone need curly feeler gauges?- and never touched the valves again.
    Who knows, I recently did an early 50’s 218 out of a car, cut the seats by hand, could definitely tell the exhaust seats were harder than the intake seats.
    Sharpone likes this.
  7. distributorguy
    distributorguy
    from MN
    Poor starting hot is typically from too much fuel or weak ignition (can't burn all the fuel). Its almost never from vapor lock. (I'm going to duck and cover now). Everyone likes that catch-all excuse that gets blamed for poorly adjusted timing. You'll soon find out that you'll want to gap your points at .016-.017" and set the timing significantly higher - like 14-18 BTDC at idle while the vacuum hose is disconnected from the distributor. It'll start easier, run cooler, and be more fun to drive!
    Joshua O'Rourke likes this.
  8. squirrel
    Poor starting hot down here in AZ is usually caused by the fuel boiling in the carb....they don't make it the same as they used to...
  9. Joshua O'Rourke
    Joshua O'Rourke
    interesting, i feel I'm getting a touch of topic here but what causes weak ignition guessing it may be a few things
    I live in Illinois this happened on cool days
  10. squirrel
    ignition problems might include dirty or misadjusted points, failing condenser, wrong timing, dirty secondary side (cap, plug wires), dirty or wrong gap plugs, failing coil, miswired feed, stuff like that.
    ClayMart, RodStRace and Sharpone like this.
  11. bobss396
    bobss396
    I have run engines with non-hardened valve seats for many miles, never a problem. I like the general clean up and lap the valves in. You can check valves to see if they are bent using a drill press or even a cordless drill. At low speed of course, a bent one will be obvious.
    If I use a head again, I use a big flat file and go over the head surface at an approx 45 degree angle to see of there are low spots, go 45 one way and then the other way. Higher spots will show up as shiny. You can also use a good straight-edge and a feeler gauge. Search out some methods, it is not rocket surgery.
    Sharpone, leon bee and RodStRace like this.
  12. Budget36
    Budget36
    Well Bob, I believe you typed to fast and maybe ? Meant to write “if I have a used head again…” etc.
    If not, no worries. I know of a lady that makes house calls, if she can’t be in your area, she’ll know someone who is;)
    Just effing with you. :)
    bobss396 likes this.
  13. bobss396
    bobss396
    Nothing like getting a little a-head in this world... :D:D:D
    Budget36 likes this.
