Technical valve spring diameter sbc
Discussion in 'The Hokey Ass Message Board' started by 30tudor, Apr 23, 2018.
  1. 30tudor
    30tudor
    Regarding early sbc heads I believe the valve springs are 1 and 1/4" in diameter, what reason is there to go to a larger diameter? 1 and 1/2" is what I measure on a pair of very nice, fresh 3917291 heads I picked up last year.
  2. doyoulikesleds
    doyoulikesleds
    more spring presure and room for lift
    30tudor likes this.
  3. jimmy six
    jimmy six
    I use 1.50's on every thing. .100" longer valves of any diameter valve too. I like to set the close pressure with at least a .015" shim under to protect the cast iron from the bottom of the spring. Good Luck...
    30tudor likes this.
  4. DDDenny
    Curious what the cast dates are on those, are they 2.02's?
    The "291" heads were the last of the true camel humps, also first year for the temp sender.
    There were some early in the production year that did not have the sender.
    I have a set on my 327 that were NOS, the GM box was labeled "initial 1968 Corvette stock".
    30tudor likes this.
  5. big duece
    big duece
    from kansas
    You can get the Comp cam beehive spring 26981-16 and still use the 1.250 pocket. Use with flat tappet or roller cam profiles up to .525 lift.
    30tudor likes this.
  6. Chiss
    Chiss
    from S.C.
    The answer to your Question is more seat Pressure. Say 120lbs vs. 180lbs, so when you Rev your Lifters are not jumping off Cam Lobes.
    30tudor likes this.
  7. Mike VV
    Mike VV
    from SoCal
    30tudor -
    As others have said, it's a "pressure thing".
    If you have an early, low lift cam and don't do any racing around, you're fine with the smaller springs. But if you have a higher lift, and or higher duration cam than the 60's "standard performance" cams, opening the pockets and installing a larger spring is a good option.
    The 1-1/4" "beehive" springs are ok, but I'd still run a larger diameter spring for more stability, even running a 1-1/2" dia. beehive spring..!
    Mike
    30tudor likes this.
