Technical valve spring locks.7 or 10 degrees.
Discussion in 'The Hokey Ass Message Board' started by coupe man, Dec 2, 2015.
  1. coupe man
    coupe man
    What determines which degree lock you use.Is it the type of valves.duel spring or single with damper.Or a performance thing.Thanks for your knowledge.
  2. greg32
    greg32
    from Indiana
    Valve spring retainer determines type needed as far as angle. Valve determines style of keeper. So you could have, as an example, single groove 10 degree
  3. squirrel
    it's a performance thing....if you run a big cam, you need a stiff spring, so you need a stronger retainer and keepers.
  4. coupe man
    coupe man
    Thanks for the reply.Which are stronger the 7 or 10 degree.
  5. squirrel
    10 degree is stronger. 7 degree is stock.
  6. badshifter
    badshifter
    You can't just change the keepers, or locks. The retainer dictates which lock you use. A 7 degree retainer uses a 7 degree lock, a 10 degree retainer uses a 10 degree lock. They are a matched set.
  7. oj
    oj
    The 10 degree are machined steel, very strong; the 7 degree are stamped out. Get the 10 degree, cost isn't an issue and you'll feel better about it.
  8. squirrel
    Also, most cam manufacturers have specific recommendations for springs and other hardware to use with their various cams....they know what works.
  9. coupe man
    coupe man
    Thanks for the replies.
