Valve Springs SBC
Discussion in 'The Hokey Ass Message Board' started by Dooley, Jun 10, 2009.
  1. Dooley
    Dooley
    from Buffalo NY
    Broke a valve spring on #7 intake, have a new set with new seals, keepers and retainers.
    What problem would i have if I just changed both valve springs on #7 for now and within a month or so changed the rest?
    other issues with the valves one spring just cracked.
  2. fasttimes
    fasttimes
    from NC
    If it was me I would just have everything checked out. Have the correct spring rate for the cam and check to see if you are having coil bind.
  3. Dooley
    Dooley
    from Buffalo NY
    The old springs were the correct springs, they are old, as they sat on the heads comepressed for about 20+ years.
    The new ones are also correct, per the cam specs.
    I know they need replacing but I want o drive this weekend and wondered if it made a difference.
  4. Dirty2
    Dirty2
    Change all the ones you can . Your just going to break another one if not .
  5. New springs or New Engine !! You pick !! Sounds like your old springs have gagged and you are on borrowed time. So far you've been lucky as in it hasn't gulped a valve YET !! Stop while you still have an engine left and change all of the springs >>>>.
