Hot Rods Valvoline oil
Discussion in 'The Hokey Ass Message Board' started by 3340, Aug 28, 2018.
    3340
    Not sure when but just realize Valvoline no longer has zinc in the vr 1 racing oil!
  2. Atwater Mike
    Atwater Mike
    Thanks for the tip!!! Valvoline 30w Racing Oil has been my choice since the '60s.
    Anybody else feeling the abandonment I am? Just 'pissed us off', like flies on a toilet rim.
    (this is the correct use of the term 'pissed off'; 'He pissed me off', 'I pissed her off', etc.)
    Nevertheless, Valvoline's omitance of the 'Z' 'PISSES ME OFF'!
  3. landseaandair
    landseaandair
    from phoenix
  4. hidez57
    hidez57
    I have a case of 10w-30 and all the bottles have a label that say high zinc.
    FortyNiner and egads like this.
  5. WiredSpider
    WiredSpider
    Mine all say High Zinc as well
  6. tb33anda3rd
    tb33anda3rd
  7. AngleDrive
    AngleDrive
    from Florida
  8. bobss396
    bobss396
    I would agree. Although I haven't bought any in a year or so. Why take the zinc out of it?
  9. egads
    egads
    Just bought some today, still say's high zinc. Where did you read this?
    FortyNiner likes this.
  10. brianf31
    brianf31
    I just ordered 12 quarts from Summit. They all had "high zinc" on the bottle.
  11. Hombre
    Hombre
    I also think this is fake news, every bottle of Valvoline racing oil I have seen says high Zinc. Now with that said the reason Zinc or more correctly ZDDP the additive pack that contains the zinc is being removed or at least reduced greatly in modern oils is it kills catalytic converters and makes them useless. That's why they are taking the zinc out.
    egads, loudbang and Johnny Gee like this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    And even more correctly, ZDDP. :D
    LOST ANGEL, loudbang, Hombre and 3 others like this.
  13. High zink lives!!!
  14. ClayMart
    ClayMart
    Correct. The little bit of oil (with zinc) that makes its way into the exhaust stream begins to lay down a layer of zinc on the platinum and iridium catalyst material, reducing its effectiveness. Lead was removed from fuels for the same reason.
    I suspect that this is also the reason for the switch to platinum and iridium spark plugs. Any material that erodes from the plug's electrodes and enters the exhaust stream is already the same material as the catalyst. And copper core spark plugs aren't nearly as common as they were several years ago.
    loudbang and Hombre like this.
  15. 26hotrod
    26hotrod
    from landis n c
    I use the 20/50 racing oil(Valvoline) for my stroker motor and it had zink as of yesterday when I bought it from AdvanceAuto………..
    egads likes this.
  16. Torana68
    Torana68
    from Australia
    Can’t se this happening, it’s a race oil not for street use? OP needs to come back and back up what he spat out with some facts .
    Edit: went to the valvoline site, says zinc , someone’s ********ting.
    Hombre, lumpy 63 and Casey Riley like this.
  17. no55mad
    no55mad
    Call the phone number on the container and ask.
  18. Mel Skaggs
    Mel Skaggs
    Contacted Valvoline engineers some years ago about the zinc issue, he ***ured me that the present formula meets the zinc specs.
    carolinakid likes this.
  19. Fortunateson
    Fortunateson
    PLEASE don't use that term. Please!
    XXL__, Truck64 and Truckdoctor Andy like this.
  20. Hombre
    Hombre
    Completely appropriate term both in this case and in some others. Hurts when it's right-don't it?
  21. Hombre
    Hombre
    Thanks for correcting me it is of course as YOU say ZDDP.
  22. LM14
    LM14
    from Iowa
    There was a time not too long ago (maybe 2 or 3 years ago) that there were 2 "types" of VR-1 oil being sold. The ON ROAD was a low ZDDP package and the OFF ROAD was a high ZDDP package. I think they quit producing the ON ROAD style a year or so ago because of the confusion. I saw both side by side at a local parts store and the difference was a small warning label that would have been easy to miss. Hopefully they saw the light and stopped making the low ZDDP VR-1 for ON ROAD use.
    That is why I just use Brad Penn, Royal Purple or other specially formulated oils for flat tappet stuff.
    My latest project I just went roller cam, tired of reading oil bottle labels.
    SPark
    Hombre and 3340 like this.
  23. 3340
    3340
    If the containers say zinc they are probably old stock, the new ones do not say zinc, and if you feel the oil it’s lost the sticky feeling,
  24. tb33anda3rd
    tb33anda3rd
    sticky feeling?
    check the link i posted.
  25. 3340
    3340
    Information was from a local racy engine builder, I haven’t called the 800 number on the container but will do today
  26. bobss396
    bobss396
    I switched to Kendall racing oil 2 years ago and I always read the label, I should se how much ZDDP is in it. Never hurts to be an educated consumer.
    Valvoline lists their zinc content at 1400 PPM, parts per million. Kendall GT1 goes by weight percent (wt %) which is .12.
    Too early to do any math...
    egads likes this.
  27. old sparks
    old sparks
    a 3 dollar can of stp each oil change solves the possible problem. read the label
  28. Petejoe
    Petejoe
    from Zoar, Ohio
    Boneyard51 likes this.
  29. Gman0046
    Gman0046
    Looks like another CNN Fake News story .
