Van Norman boring bar setup info
Discussion in 'The Hokey Ass Message Board' started by KenC, Apr 6, 2007.
  1. KenC
    KenC
    I have been loaned a Van Norman 965 for my use as long as I want!
    Only problem, I haven't used one of these in years. Looking for setup instructions. Anyone know of any info online?
  2. kb cookout
    kb cookout
    What kind of motor are you bore out? let me know what set up info you need help with.
    later kb
  3. I'll look through my stash and see if I have anything. What, specifically, are you looking for?
  4. squirrel
    step one: scout around the yard for junk blocks to practice on
    I've only used a 777 and it's been several years....
  5. KenC
    KenC
    I need the cutting tool and guide installation and adjustment info. and If possible a picture the clamp/holdown setup on the block.
    My first project is to bore the dry sleeve out of a Mitusubishi diesel. Then I have a couple of small engines (kohlers) to bore. Then an old tractor 4cyl. And, if I ever get to it, a 235 chev.
  6. KenC
    KenC
    Yep, got a couple already! Great advice. Don't want to make my inevitable mistakes on hard to replace good old stuff.
  7. 2manybillz
    2manybillz
  8. 2manybillz
    2manybillz
    The one thing I learned from experience with any of the block mounted bars regardless of the hold down, you need to have as much of the bottom of the bar and the surface of the block in contact as possible. Friction keeps the bar from moving - tightening the **** out of the hold down without much surface contact = sleeve time. I speak from experience. That's a big reason boring fixtures came about - thinwall V-8s with minimal deck surface - not much to grip the bar.
  9. buffaloracer
    buffaloracer
    from kansas
    I don't know what a 965 looks like but if it is like my 777 it is worth the trouble to tap a piece of pipe to use in the main bearing location as a hold down. There are a couple of people usually on ebay that will have the appropriate instructions.
