Vandalizing a '63 Falcon's engine
Discussion in 'The Hokey Ass Message Board' started by BurntOutOldMechanic, Jan 20, 2013.
  1. F91
    F91
    Yep, sleeper! Very cool.
  2. dblgun
    dblgun
    Nice clean job you did there.
  3. kyvetteman
    kyvetteman
    Man I bet that things scoots! Thanks for a very well-written thread. I enjoyed following along.
  4. Great post,,,now it looks like you need the "Shelby Drop",,,get it closer to earth all the way around....:p
  5. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    It handled a whole lot better after I ditched of all the twitchy mix-n-match power steering stuff:
    63 Falcon 6cyl P/S center link n' pittman arm , 65 Falcon/Mustang V8 idler arm, 65 Mustang P/S control valve ***embly, Granada outer tie rods n' adjuster sleeves, 63 Falcon P/S inner tie rods, unknown/unmarked ***ist ram, an' some dudes home-made steerin ram mount ...it's stomp-down amazin' this **** all actually steered the car, as bound up as it was.
    Dude, I was just too lazy ta' do the Shelby drop when I swapped out all my rusty 50 year old front end junk. It got new upper n' lower control arms, spring perches n' springs, along with new strut rods n' all the bushings.
  6. That little white car is even nicer in person. Always amusing, Al. Anybody else catch that "listening to Monk" part?
    Just like your posts, my friend, Straight, No Chaser.
    http://www.youtube.com/watch?v=HwfA59_6RFM
  7. Old Mech,, shiney stuff underneath is good too,,,,when I did a '63 HTP back in '70 or so, I never heard of the "Drop",,,cut a coil & blocks put mine down. Had to replace those spring trunnions tho'.
  8. HoosierBuddy
    HoosierBuddy
    from Indiana
    I ran that holley fuel pump on my 289 for a while. Had a lot of trouble with it. It always wanted to vapor lock like a SOB. I kind of figure the pump is overkill on a stock SBF and may pull more vacuum in the fuel line than a stock pump, which could contribute to vapor lock?
    Don't know for sure. It was bad enough the car (Mustang) was unreliable if the outdoor temperature was above about 95 degrees. Eventually I installed a cheapo electric fuel pump at the tank to pump fuel to holley fuel pump. That band-aid fix worked.
    Eventually I converted the car to EFI and that's how it is today with no mechanical fuel pump. It's electric in tank (tank's inc. kit).
    So...if you start having trouble with vapor lock...that's where I'd start....ESPECIALLY if you necked up from a 5/16" fuel line to feed the mechanical pump.
    Great pictures by the way!
    Phil
  9. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    The dude I got the car from had tole' me that he'd replaced the fuel pump recently. When I was doin' the tear down for the cam I discovered this:
    It's kind'a hard ta' see in this picture but note the two piece fuel pump excentric that's missing the outside shell of the excentric, making it a one piece that would never ever give the fuel pump a full stroke.....
    This is 'cuz some previous buthcherin' heathen put a later style timin' (chain) set on it and and then discovered 1968 timing cover he chose ta' use wouldn't go back on without removing the outside piece of the fuel pump excentric. This is prolly the same dude that used a piece of all-thread and a nut for a water pump bolt and jacked up the timin' pointer. I ain't a big fan of the two piece so I went with a one piece excentric an' the appropriate timing set for it.
    So rather than take a chance on the other over worked pump, I went wit' the Holley. We'll be seein' how it all works out.....
  10. ClutchDumpinDan
    ClutchDumpinDan
    Looks awesome Al! I've felt the "before", I'm ready for the "after" ride around the block :cool:
  11. ClutchDumpinDan
    ClutchDumpinDan
    I like how organized all your spray bombs are :D
  12. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Dude, thanks fer' lettin' me use 'yer lift when I did the control arms n' springs n' bein' willin' ta' get on the floor fer' an old burn-out.......
    You got way too much time on yer hands now that ya' finished that Plymouth...now get back to work or I'll post that other picture I got of ya'.......
  13. 60srailjob
    60srailjob
    from nowhere
    wow man great thread......very meticulous...alot of detail....I like it.....
  14. sololobo
    sololobo
    I was hoping to see a shot of the whole damn rig, post it up dude. Nice mill work! ~sololobo~
  15. Veach
    Veach
    Damn dude you got me Laughing so hard I had to take a shot and two pills.That was great .I was a diesel monkey for a few years so I know about that airleak and I was in the Army a few years so I know bout them ears too.I had them boys move that tv and put it on the wall sleeping better.I ate at the table the other day which was stupid now no more getting my food brought to me.You motor looks good be glad when I can get back to the shop.Pills are kicking in will let you go.I Thank You Very Much couldn't get thro this by myself.Your Friend Steve
  16. tommyd
    tommyd
    from South Indy
    Not to worry, that excentric will make it's own clearence on the backside of the cover. Did that....once....:D.
  17. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    60srailjob n' sololobo, thanks for the compliments.
    The more I lurk 'round here, the less I realize I know.
    Veach, my friend, I'm glad to hear yer' feelin' better. You'll be up in around in no time; belive me brother, I know where you're commin' from.
    Experience is a dear teacher, ain't it tommyd?
    Sometimes I do **** so stupid, it amazes even me......
    That junk yard genius dude prolly gave up when he discovered he couldn't get the pin out'ta the cam ta' put the longer pin in for the one piece excentric.....if he had a longer pin, and the right excentric, and the right timing set....
  18. Veach
    Veach
    Can someone tell me at what point do you stand back and say damn I finished Her ?
  19. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Stay tuned for: "Vandalizing a '63 Falcon's (1990ish AOD) transmission"....
