Variable Speed Oscillating Multifunction Power Tool
Discussion in 'The Hokey Ass Message Board' started by blowby, Mar 17, 2013.
  1. blowby
    blowby
    from Nicasio Ca
    Say that 3 times fast. Do these things have any place in the hot rod world? How about personal hygiene?
    Yes, I'm reading the new HF flyer. :)
  2. blue 49
    blue 49
    from Iowa
    I bought one (not HF) a while back to help me remove countertop in our kitchen. It was pretty much worthless for that job. Tried it to s****e sound deadener from the inside of my car and it didn't work for that either. Might work as a detail sander but I already have one. Pretty limited tool.
    Blue
  3. BOBCRMAN
    BOBCRMAN
    from Holly
    With the proper end tools, can really save time with s****ing, windshield/gl*** work. Great for flooring, drywall and trim work in the house. :D
  4. noboD
    noboD
    About the only tool I've ever bought there that actually works is my 2 lb hammer for $3.
  5. chinarus
    chinarus
    from Georgia
    I bought a HF one and the cutting blade has been handy for home renovations such as drywall, pvc tubing, or other hard to get at trim cuts. I wore out the first blade cutting thru some molding with nails but it worked.
    Gonna try to redo the grout in the bathroom with the diamond attachment but haven't found a use for it the tool the garage yet. If I did more home renovation work I would spring for a higher priced version.
  6. blowby
    blowby
    from Nicasio Ca
    Thanks guys. I try to avoid home repair like the plague. Thought maybe it would be good for sanding in tight areas on the car you can't get with a DA. No toothbrush attachment either then eh?
  7. HOTRODPRIMER
    HOTRODPRIMER
    No,,HF tools **** and I can't imagine a use for this piece. HRP
  8. chinarus
    chinarus
    from Georgia
    I have a Ryobi detail sander and 4 inch pad sander I got at Home Depot for tight sanding spots. They both do a good job, the quality is a step up from HF and the price wasn't too bad.
  9. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Have the original one, not the multi speed. Use it all over on house renovations, but never touched it on the cars.
  10. vtx1800
    vtx1800
    I've worn out one (well it's on it's last legs) and bought another, don't use it much on cars (yeah I know that was the original question) but if you do any work on your house it will save time and keep your blood pressure lower so you have more time to work on your car.
  11. Mike51Merc
    Mike51Merc
    Is there a "marital aid" attachment available?
  12. 56FRLN
    56FRLN
    I've used mine a bunch but it has all been home repair type stuff. Haven't found a use for it in the garage yet but you never know.
  13. choptop4
    choptop4
    I use mine just about everyday.When the blade is gone, I cut it off and tack weld the old part of a sawsall blade thats still good . Or a hack saw blade. Save lots of cash . And they cut better .
