Vega or Corvair steering box?
Discussion in 'The Hokey Ass Message Board' started by BC Texas, Jun 25, 2013.
  1. BC Texas
    BC Texas
    from Arp. Texas
    What are the differences between the Vega and the Corvair boxes? I'm building a 29 coupe with 283 and auto ******. Full fendered and chopped 4 1?2 n. I'm using cross steer and want a quick and easy turning car without power steer or rack and pinion. Which would you use and how does the ratios differ? higher the number, less or more turns lock to lock? I see adds for 15:1, 16:1, 20:1, 20.9:1, and 22:1
    Thanks for any info
  2. HOTRODPRIMER
    HOTRODPRIMER
    Vegas are much easier to find. HRP
  3. woodypecker
    woodypecker
    vega for cross steer. Reversed Corvair used mostly on T bucket side steer.
  4. jaw22w
    jaw22w
    from Indiana
    Definitely a vega box for cross steer. A 15:1 box is less turns lock to lock than a 20:1 box. A 15:1 box requires more steering effort than a 20:1 box.
  5. BOBCRMAN
    BOBCRMAN
    from Holly
    Corvair is too light duty for anything more than a very light T-bucket type car..
  6. A Boner
    A Boner
    You can reverse a vega too.......just have to also machine clearance to fit u-joint on.
  7. Fourdy
    Fourdy
    Can anyone tell me where to get the 15 or 16 to 1 ratio vega box. I believe my stock vega is 20:1 and bothersome to me.
    Thanks
    Fourdy
  8. d2_willys
    d2_willys
    from Kansas
  9. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    I find Corvairs easier to find. Im never really looking for steering boxes, but buy them when I find them at swaps. I have 1 Vega box on hand, and probably 40 corvairs :D
  10. ago
    ago
    from pgh. pa.
    Cl***ic Performance products has a 13.6:1 ratio Vega power box.
    Ago
  11. Mr48chev
    +1, the only thing that they have really been used on hot rod wise with some degree of success is T buckets that have the same or less weight on the front wheels as the original Corvairs did.
