Technical Vega steering Box
Discussion in 'The Hokey Ass Message Board' started by 1124jhh, Nov 17, 2023.
Tags:
  1. 1124jhh
    1124jhh
    from Auburn,CA
    Installed Speedway steering box with their bracket. Pitman arm points down at about 30% which makes it very low to ground with 4” dropped axle. Any help appreciated.
  2. krylon32
    krylon32
    from Nebraska
    Pete& Jake's sells a stepped steering arm for the Vega. I've used a few. Just make sure to tell them you want to raise the drag link not lower it.
    catdad49 and dana barlow like this.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    IF its a forged arm , heat & bend ..
    dana barlow likes this.
  4. alchemy
    alchemy
    If you have a forged steel pitman you can heat and bend it.
  5. HOTRODPRIMER
    HOTRODPRIMER
    Heat & bend. HRP
  6. krylon32
    krylon32
    from Nebraska
    If it's a Speedway pitman it might not be forged?
    X38 and lumpy 63 like this.
  7. 1124jhh
    1124jhh
    from Auburn,CA
  8. Mr48chev
  9. 1124jhh
    1124jhh
    from Auburn,CA
    Decided to get Speedway 2” offset pitman arm cut and reverse the spline end. Thanks to all for help in making decision, checked with Pete and Jake’s, think heat and bending a 6” shaft unwise.
  10. krylon32
    krylon32
    from Nebraska
    I have put my faith and reputation in Pete & Jake's parts since I became a dealer when they started. Can't say the same for Speedway. Pete & Jake's arms are laser cut steel and cold bent in a press. Dam sure safer than cutting and re welding a Speedway arm.
    RICH B, 60 Special, warbird1 and 5 others like this.
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    Well there's those that can & more those that shouldn't
    What 6" shaft ,you bend the steering arm ,no " shaft" involved....
  12. Fordors
    Fordors
    I’m not suggesting that a flame cut and cold bent pitman would be inferior to a steel forging but I do question why a forging should not be heated and bent? Guys have done that for decades to pitman arms and steering arms and if done properly the forging isn't compromised in any way. My big concern is the Speedway steering box, and correct me if I'm wrong but I believe you are putting that in a '40 Ford. The Borgesen 525 box would be a better choice, or even the Borgesen Vega box in a '40 for that matter.
  13. X38
    X38
    This may seem pedantic, but some things irritate me, so I have to say: Speedway do not make steering boxes, they sell them.
    And I agree with @Fordors about the steering boxes.
    Just Gary likes this.
  14. krylon32
    krylon32
    from Nebraska
    Read this guys post. He's talking about cutting a reversing the splined end. Not a fan of anything welded on the steering.
    X38 likes this.
  15. Fordors
    Fordors
    I’ve been wondering about the need to cut and weld, the Speedway pitman has a two inch drop, sounds like he wants to raise the drag link?
  16. krylon32
    krylon32
    from Nebraska
    I have read the posts on this thread repeatedly and cannot believe what I read. I have used 100's of P&J's Vega steering arms in the 40+ years I built ch***is with no problems. To compare the quality of their USA made arms to the Chinese **** that Speedway sells is an insult. Same with the steering boxes. Chinese made steering box versus American made Borgeson Vega boxes baffles me. I know some of you are on a tight budget but steering is no place to sacrifice quality. When I started back in the 80's I couldn't get a Mullins dealership so I sold probably 50-75 Vega boxes sold by an a American company but made overseas. That didn't take long to bite me in the ***. Box failures, leaks, rapid wear, no adjustment. The company I bought the boxes had the standard response (never had those problems before) I did my best to help the customer and finally got a Mullins dealership and began using his rebuilt GM Vega boxes and eventually Borgenson. Cutting and welding steering components is a risky business. Different story, heating bending steering arms on Henry Ford spindles, even that should be done by an experienced fabricator and always magnafluxed for cracks after they're bent. I may get a little carried away but I've seen steering failure and the consequences.
  17. twenty8
    twenty8
    This can be a lesson that is sometimes learned the real hard way.......
    Just Gary and elgringo71 like this.
  18. 19Eddy30
    19Eddy30
    from VA
    Steering box mounting plate not properly /welded in correct angle , the Spline side for steering column should be parallel,
    Pitman side shaft vertical,,
    Pitman / cross steer should be @ close to same plain as steer tube @ ride height
    flynbrian48 and warbird1 like this.
  19. RICH B
    RICH B
