vent glasses
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by THEAD, Feb 8, 2013.
  1. THEAD
    THEAD
    still working on my 54 f-100, Making good progress.Need some advice on installing vent gl*** into the frames, which is best setting tape or silicone?
  2. 1934coupe
    1934coupe
    Welcome THEAD, I don't think you want to use silicone. The tape is what was used. An old gl*** guy told me that the silicone never comes out and you have to break the gl*** into little pieces to clean the frame out if you ever have to replace it again.
    Good Luck
    Pat
  3. staypoor53ford
    staypoor53ford
    from wisconsin
    I used the Tape went in easy holds tight no complaints from me
    and to get it good and tight I used a mallet to help it in Didnt take to much just made sure it was seated good
