vent glasses
Discussion in 'The Hokey Ass Message Board' started by THEAD, Feb 8, 2013.
  1. THEAD
    THEAD
    What up fellows, still working on my 54 f-100. making good progress.Trying to install gl*** in my vent frames. Need some advice on wether to use setting tape or silicone?
  2. HOTRODPRIMER
    HOTRODPRIMER
    I used setting tape in the vent windows of ladyhrp's 1954 Ford Ranch Wagon. HRP
  3. okiedokie
    okiedokie
    from Ok
    I used setting tape on my 53F100.
  4. BOHICA
    BOHICA
    Do you get setting tape from NAPA/an auto body shop or is it something you have to special order? I'm going to have to do this on my '53 F-100.
  5. shinysideup
    shinysideup
    from ruskin, fl
    I used the tape, plenty of windex, and a rubber mallet.
  6. fordor41
    fordor41
    Any gl*** shop that does auto gl*** should have it. Take your frames so they can match the correct tape to the new gl***/frames.
  7. robertsregal
    robertsregal
    setting tape as stated it comes in many thickness, look at the old stuff that will give you a idea. I had a couple thickness on hand so I would'nt have to run 12 miles to get more.Rubber mallot and lots of lube you can get it done.
  8. theHIGHLANDER
    theHIGHLANDER
    Silicone on that job is for hacks...
  9. Dane
    Dane
    from Soquel, CA
  10. greaseyknight
    greaseyknight
    from Burley WA
    Yep, be sure to get the correct thickness of tape, any good gl*** shop should be able to help you out. Their is several types, an all rubber, and a fabric backed stuff with tar in it. No sure which is the best, as I used both in my F-3. But getting the correct thickness is vital, and will save alot of headache.
    I also used a woodworking vice to help push the gl*** in, the type with wood jaws.
  11. texasred
    texasred
    from Houston
    if you use silicone, go to a gl*** shop and get a tube of du pont 795 or 799 black
  12. second_floor_loft
    second_floor_loft
    A buddy of mine made a quick frame the shape of the vent out of MDF...put the tape in the window frame, slide the frame into the MDF to hold it's shape and hold it still and then press the gl*** into place. A little soapy water or windex and you're good to go.
  13. Rodders
    Rodders
    i used tape and got it from the gl*** shop
