Vent window frame rivets
Discussion in 'The Hokey Ass Message Board' started by chevyrulezzz, Oct 31, 2012.
  1. chevyrulezzz
    chevyrulezzz
    from Holland
    I like to rechrome the vent windows of my '53 chevrolet 210, but to have a good result, I have to drill out the rivets.
    Does anybody know who sells these or is there another nice solution to put it back together ?
    All I can find are rivets for a '53 truck, but I'm not sure they are the same as I need.
    I mean the ones marked with the red arrows. The ones with the green arrow I have already.
    Thanks a lot !!!
  2. 49ratfink
    49ratfink
    chevsofthe40s.com might have something like that
  3. olscrounger
    olscrounger
    get them at ACE Hardware for vent wings on 40 Fords
  4. chevyrulezzz
    chevyrulezzz
    from Holland
    I already checked chevs of the 40s, National Chevy association and Truck and Car Shop, but cannot find them there.
    I'm not familiar with Ace hardware (living in Holland) and wouldnot know what to look for.
    Anyway, big thanks your fast replies !!
  5. deto
    deto
    Im chopping my vent windows down. If I come up with a solution or find a rivet to use I will keep you posted.
  6. Leakie
    Leakie
    They were probably chromed as a unit, not pieces. Can you have them chromed the way they are without taking them apart?
  7. butcherted
    butcherted
    from hagerstown
    <!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--> I had them chromed on my 50 Chevy in one piece.
    <!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} </style> <![endif]-->
  8. They were chromed then assembled before the install. Used to have some of them but have used and given them away. Hardware store should have them.
  9. FLAT-TOP BOB
    FLAT-TOP BOB
    HAMB O'dex Editor
    i use brake shoe rivets and reinstall them with a brake shoe riveter
  10. Pinstriper40
    Pinstriper40
    I'm putting the vent windows together on my '40 Ford... I'll have to check out the brake shoe riveter idea. Anyone else have any input?
  11. The frame is chrome plated, the vent lock is stainless steel.
    Looks like the same thing on my '57 Chevy. Try one of those vendors.
  12. Mike51Merc
    Mike51Merc
  13. hotrod mike
    hotrod mike
    OPGI has them for 60's GM cars but not sure if they are the same as what you need. They're about $6 for a pair of them. I just ended up using pop rivets on my 67 Vista Cruiser. So far, so good :D
  14. 66nova383
    66nova383
    Yhe filling station in Lebanon OR. has them I got some a couple a months ago.
  15. rusty28a
    rusty28a
    Man, that's one heck of an idea right there!
  16. jcmarz
    jcmarz
    from Chino, Ca
  17. I got them at Ace hardware. HRP
  18. Tin Can
    Tin Can
    I used an aluminum rivet in the lower area, smashed them down with a punch after they were installed. the window will cover this end of the rivet. For the upper pivot I used the aluminum rivets to connect it to the wing window surround, for the upper hinge to the car mounted part I ordered the rivets from national chevy association and made a home made tool out of a generic c clamp with a grinder.
