Hot Rods Vent window handle shaft removal
Discussion in 'The Hokey Ass Message Board' started by Jason Taylor, Apr 11, 2015.
  1. Jason Taylor
    Jason Taylor
    How do you remove the vent window handle shaft on a 1950 chevy 2 door sedan ?
  2. Hdonlybob
    Hdonlybob
  3. Jason Taylor
    Jason Taylor
    I took out the roll pin that held the actual handle on . I need to remove the shaft that the handle moves on its ridgid mounted . Just trying to dis***emble to re chrome everything
  4. Jason Taylor
    Jason Taylor
    The link you sent doesn't take me anywhere . Sorry I tried to use it .
  5. The link he posted is for door handle removal. I don't think the vent window shaft is removable.
  6. pat59
    pat59
    Na on the 50 the vent handle is still on the vent itself. (at least my 51 Fleetline special is that way)
  7. Hdonlybob
    Hdonlybob
    Sorry 'bout that. I read incorrectly that you wanted to remove the shaft.
    My Bad :(
  8. Jason Taylor
    Jason Taylor
    YA the shaft is on the frame handle is off its not molded or anything so I think it has to come off to be able to chrome the piece its attached to that is removable from the frame it is the same as a 51 ImageUploadedByH.A.M.B.1428930650.123373.jpg there is another piece it is attached to that is riveted in so I want to take it off to chrome that piece and the rest of the parts that come off .
  9. 24riverview
    24riverview
    Not exactly sure what you are asking, if you mean the shaft the latch handle goes on it's part of the frame. Vent.jpg
  10. Jason Taylor
    Jason Taylor
    Yes how to you get the shaft off the piece that attaches to the frame
  11. Jason Taylor
    Jason Taylor
    I actually have them apart and are taking out the rivets that hold everything together once I do the shaft that has the handle attached to it I would think has to come off so that piece can get chromed and I think it's a big rivet but not sure ?
  12. alittle1
    alittle1
    Doesn't the gl*** have to come out first and then you can get at the back of the spring-loaded opening pin to undo the countersunk screw behind the rubber weatherstrip. The screw mounts into the back of the base plate. Fords have the drive type roll pin!
  13. 54vicky
    54vicky
    is that frame(part gl*** is in)not stainless steel.if so why try to chrome?
  14. Jason Taylor
    Jason Taylor
    No it's not stainless and I have the gl*** out now it doesn't have a screw in the shaft it's just a picture I took for reference I know how to take it all apart just not sure how to get the handle shaft off its chrome not stainless and rust is coming through it
  15. 54vicky
    54vicky
    that explains that in this case a pic not worth a you know the rest
  16. 24riverview
    24riverview
    Just ***embled these on 49 Olds I'm working on, they were replated without removing the latch pin and came out just fine.
    Jason Taylor likes this.
  17. Jason Taylor
    Jason Taylor
    Thanks that's what I was wondering wasn't sure if that would work
