Hot Rods venting fuel tank
Discussion in 'The Hokey Ass Message Board' started by sdluck, Mar 20, 2024.
  1. sdluck
    sdluck
    If you are using our remote rollover vent valve # VVR make sure that the vent is mounted vertically. Mounting the vent at an angle may cause the vent to shut off.I didn't see this before.
    If you are using our in-line remote rollover vent valve # VVR-IL make sure that the vent is mounted vertically with the check ball in the bottom fitting. Mounting the vent at an angle may cause the vent to shut off
    Bcap55 likes this.
  2. Bcap55
    Bcap55
    from PA, USA
    Thanks for the heads up, I will be using that setup on my project.
  3. RMR&C
    RMR&C
    from NW Montana
    What was the question?
  4. sdluck
    sdluck
    Guy's having problems filling aftermarket fuel tanks
