Technical Vertex Magneto
Discussion in 'Traditional Hot Rods' started by Bonehead II, Sep 28, 2020.
  1. Bonehead II
    Bonehead II
    Hey all...I have a wore out vertex magneto that I am wanting to run it as just a points distributor, that way I can use the MSD boxes that I have. How do I get the guts out of the main body, I can't see how it comes apart. Thanks Mike
  2. AULIZ
    AULIZ
    Why not use it like original Magneto? 100% better spark and trusty.
    427 sleeper and LAROKE like this.
  3. Jmountainjr
    Jmountainjr
    Carefully! After removing the cap, points plate, and the advance plate (if any), you should see the two long screws that run down through the bottom.
  4. Bonehead II
    Bonehead II
    Jim I can't get the points plate off....&$^#
  5. oldtom69
    oldtom69
    from grandin nd
    believe the "points plate" is part of the main casting-why are you ruining a $250[minimum core price] mag to build a $50 distributor? Most vertex dealer ads will show a take-a-part diagram
  6. oldtom69
    oldtom69
    from grandin nd
    two nuts by the base that come up from the bottom hold the mag together-they require a special screwdriver[or make one]to remove-be aware the breaker cam is attached to the magnet shaft on a taper with no keyway-takes another special tool to align that-you remove the magnet,you no longer have a shaft coming up to mount the points cam,rotor etc.when you take the base off you will see if the mag has advance weights or is "locked out"Please save all the parts for someone that does mag repair
