Vertical MIG welding: uphill v. downhill
Discussion in 'The Hokey Ass Message Board' started by mr.fahrt, Mar 8, 2010.
  1. John_Kelly
    John_Kelly
    Uphill welding requires that you either set your machine perfectly and run a bead straight up with no washing back and forth (or maybe just a little), or you wash back and forth as a way to have a wide, slightly crowned bead. The wash helps you control the sag if done right. You will have more distortion on lighter weight materials though. Sometimes whipping across the middle and holding at the sides briefly before whipping across the middle again is the way to go. It's all about controlling the puddle. If it is sagging in the middle, go across the middle a little more quickly. If it is undercutting as seen in the one picture, stay at the edge just a little longer so the wire can deposit a little more weld....maybe crank up the wire speed a little. You can make a 1" wide bead if you want to. Make sure your cover lens is new so you can see what you are doing. Practice! An inside corner weld is actually easier because you can use the valley to hold the weld puddle from drooping. You can move the weld puddle in 3 dimensions by going into the corner, pulling back to one side, going back into the corner and pulling back to the other side. Downhand is easy and good enough for a lot of stuff, but if there is any doubt about strength weld uphand.
    John www.ghiaspecialties.com
  2. jdustu
    jdustu
    from Detroit
    When I was doing some vertical up stick training, the CWI explained it to me like this:
    Say you're down south in a pick-up truck with a couple of buddies, and you're p***ing a bottle of whiskey back and forth. Guy in the p***enger seat gets a swig, then the guy in the middle, then the driver, back to the guy in the middle, back to the p***enger seat, and so forth....who gets the drunkest?
    So you wanna p*** over the middle quickly :D
  3. SPEEDBARRONS
    SPEEDBARRONS
    Hey John, met your brother and worked with him at Seattle shipworks this season, poor guy, under valued.... anyway yeah welding, lots of practice, this years practice for me was stainless welding with rod on ships factory, lightning fast with better results than tig and a prettier pattern
  4. John_Kelly
    John_Kelly
    Yeah, my brother has been slowed down a lot by lead poisioning from a job he did a while back. Wish he would get out of that shipyard ****. He's had a good long run at it. I got out after a few years.
  5. Steelsmith
    Steelsmith
    Hi guys! Thought I'd chime in here, for most automotive work you're only talking 1/8"-3/16" material. As long as your metal is ground clean to start with, either method, up or down hill will work.
    However, for appearence and penetration on automotive weight material I use the 'Hot S***ch' method and vertical up. These are intermitant pulses of the trigger creating well blended interlocking spots of weld. Properly timed (we're talking fractions of a second here) the pauses between blips are just enough time for the puddle to freeze before triggering again.
    It goes like this, with the gun held at about 45 degrees to the seam, (pointed up) trigger the weld. Hold steady and wait for the 'blip' to go round, let go the trigger before the 'blip' sags too much. Immediately aim at the leading edge of that first puddle and trigger again, let it go round. This second 'blip' will hang better as it is supported by the preceeding 'blip'. Again, let go the trigger before the 'blip' sags. and continue!
    If the weld you are creating looks too fat, cut back the wire or raise the voltage just a bit at a time until you get the right balance.
    Using this method, a skilled weldor can weld in any position, around tube joints as needed.
    No, it's not as easy as it sounds but it is well worth the effort to perfect this specialized type of welding for light industrial work.
    Dan Stevens
    dba, Steelsmith
  6. UA_HoBo
    UA_HoBo
    from Oswego NY
    In the pipe welding industry there is only 1 downhill test. In true testing situations if it has been deemed that you downhilled anything past 10-2 oclock you will fail your test. The down hill test is for 6010 pipeliners, providing a good fit up up hill is as quick or quicker than down and the penetration can be controlled better.
  7. Steelsmith
    Steelsmith
    That's the funny thing about welding there's many ways to skin a cat. Unless there is a specified weld technique for an application, it is up to the shop you are working for as to what is acceptable. That is why there are so many differing thoughts on what cons***utes a good weld.
    Just remember there are many different welding techniques. They were usually developed for a specific application and then adapted to other uses. In the old car business your main concern should be strength/safety.
    Weld-on!
    Dan Stevens
    dba, Steelsmith
  8. Three Widow's Garage
    Lots of good info here. My .02 worth joint design and fittment are as important if not more than the welding direction, like in this case the weld aroud the tube would fail before the backing plate would tear away from the frame. I find having a gap slightly less than the thickness of the the metal works well bolth for appearance and weld strength usualy weld down hill on up to 3/16
  9. gimpyshotrods
    gimpyshotrods
    For thin stuff, like 1/4"-3/16" and below, down is fine, so long as fitment and surface prep are all good, and that provided your machine is capable.
    For all else, up can be stronger, technically, but most here are not welding over 1/4" very often. It is harder to do well, and takes a lot of practice.
  10. 61bone
    61bone
    A downhand fillet is going to have no root penetration and will often have voids at the root on anything thicker than 12g. You are relying on good looks to hold the welded pieces together. A **** weld will have little penetration and often coldcasts. Don't believe this? Make a few practice pieces and break them. They will always break in the weld or at the edge of it.
    Strange that Caterpillar writes in their service manuals that Downhand welds are not acceptable for repairs if that is how they make them at the factory.
  11. the shadow
    the shadow
    I like to weld my vertical joints up but while I'm inverted...so I guess thats down?
  12. Well said. We call it "feathering" the trigger. Produces a nice looking weld & structurally sound.
  13. 1320/150
    1320/150
    yes!!
  14. 32Essex
    32Essex
    from Texas
    Needless to say you can learn something from these welds, flawless dude !
  15. mr.fahrt
    mr.fahrt
    Kirk Hanning:
    Thanks for all the info, everyone. I like those welds. I have done similar welds before, those intermittent trigger pulls, overlapping spots. Wasn't sure if it was technically correct or frowned upon, so it's good to hear that it's a good technique.
  16. brucer
    brucer
    from western ky
    this is what i do, downhill side to side in a criss-cross like pattern..
  17. We teach MIG welding on 3/16" plate and all vertical welds are run downhill. For good quality uphill MIG welds you need a fill wire other than the usual ER70-S2. A couple techniques to insure good downhill penetration... On open root welds (corner or **** joints), open the root gap slightly. Also try a "continuous s***ch" motion on the downward travel. Without releasing the trigger, skip the wire downward to the leading edge of the puddle as soon as the bead size is sufficient. This allows the heat to get back into the root of the weld instead of building on the surface. With practice, this can produce very good looking welds with penetration equal to horizontal welds.
  18. CrazyTalkCustoms
    CrazyTalkCustoms
    from MN
    I came across a site once where a guy did some cross sections under a microscope to compare vertical welding. He did 3 techniques, vertical welding from top to bottom, a triangle technique from bottom to top, and an upside down V pattern(which is what people are calling the christmas tree pattern) from bottom to top.
    Here is one of the pictures from his site:
    From left to right the pictures go as follows; the welds themselves, vertical from top to bottom, triangle technique(bottom to top), and bottom to top christmas tree. Note: the picture of the welds themselves is indexed wrong to the microscopic cross section pictures. Follow his drawings on the plate itself for corresponding cross section.
    Hard to argue with the results when you have a picture of a cross section under a microscope. However, with that said, most of my vertical MIG welds are done from top to bottom because I always felt that a good top to bottom weld is better than a shotty bottom to top weld. :)
  19. Krash
    Krash
    from Cleveland
    I always heard "get down, don't **** up" at the body shop I worked at back in the day. Meaning weld downwards. The dude was refering to welding sheetmetal. I do both depending how good I can see the area or access I have to the area.
