Very little legroom so where to put the headlight dimmer switch?
Discussion in 'The Hokey Ass Message Board' started by Max Gearhead, Jan 19, 2012.
  1. With barely enough room for three pedals and two feet in a 34 Ford pickup where's the best spot for the dimmer switch?:confused: Firewall, dash, side panel? Anyone solved this problem? Thanks.
  2. treb11
    treb11
    I used the HL switch from American Autowire that has 4 positions. Off, Park, Low, High
  3. I like them in the kick panel, learned that one from my old boss. You just hit it withthe side of your foot.
    Tim likes this.
  4. Cerberus
    Cerberus
    Recently there was a very good thread on dimmer switch location with a lot of good ideas/solutions. Do a search and you should easily find it.
  5. I use two toggle switches when I don't have a lot of room. One turns on the lows and the other turns on the highs. I guess that is a little backyard but it works for me.
  6. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    Exactly what I did to mine. The majority of the switch is hidden behind the panel.
  7. alchemy
    alchemy
    There is a universal switch made like this by Cole-Hersee (electric part manufacturer). See if you have a local C-H dealer. Or Speedway sells it too. I'm gonna use one in my narrowed T.
  8. Boones
    Boones
    from Kent, Wa
    1. Northwest HAMBers
    kick panel is where I put mine, also used a switch under the dash once
  9. Atwater Mike
    Atwater Mike
    T Bucket pilots install them in the front of the seat riser, most of the wiring and components are in there also...dimmer switch button is easy to push below your thigh, but you've gotta use your hand.
  10. the-rodster
    the-rodster
    Regular Headlight switch.
    One click - low beams
    Two clicks - high beams
    Rich
  11. djust
    djust
    from Oklahoma
    Exactly what I did.
  12. Hot Rod Chris
    Hot Rod Chris
    Or u can run a toggle switch with double throw with an on off on. So u run ur lights front the headlight swith normally and leave the toggle always down for lows, then switch it up for highs. That way u only rub one switch instead of two.. thats how I set up my motorcycles.
  13. Don's Hot Rods
    Don's Hot Rods
    from florida
    I just use a three position push pull switch. In all the way is off, one click out is low beams, two clicks out is high beams. I run two relays, one for low and one for high beam. Foolproof and if you want you can incorporate a dash high beam indicator by just running a second wire to that light off of the high beam side.
    Don
  14. I put a regular pushbutton dimmer switch behind a non-functioning dash lighter, nobody ever knew and it was very convenient.
  15. Directly under the dash, set back about an inch. My 26 and 28 were that way. You can't hardly see it, and you just reach straight ahead, arms length under the dash and hit the button. Standard GM foot operated switch, not much pressure as you might think, hit it with your thumb. Position it right and you dont even have to look or search for it. 3 less wires you have to run down to the floor too. TR
  16. Fenders
    Fenders
    I did just that in my current coupe -- a single pole, double throw, center off toggle switch. up = hi, down = low, center = off.
  17. Aviator
    Aviator
    In my '33 truck, I use a toggle switch mounted on the dash with a double throw (on-off-on). Works great.
  18. Jimmy2car
    Jimmy2car
    from No. Cal
    32 Ford:
    I put it below the clutch. It is not in the way and works well. I really like a floor mounted dimmer switch
  19. 26 roadster
    26 roadster
    I ran H-4's in one 27 and just used one beam....ON....they were very bright and the adjustment was critical or you got high beamed a lot. No inspection here
  20. Harry o
    Harry o
    from Georgia
    On the steering colum maby ...
  21. HarryT
    HarryT
    I put it under the dash on the steering column support, right next to the horn button.
  22. chop32
    chop32
    On my '32 pickup I mounted a normal floor mount dimmer switch on the cowl brace that runs from the front of the door jamb to the firewall and just click it by hand.
  23. big bad john
    big bad john
    ......I use the same thing for years....work fine.....then a friend suggested a single toggle switch with a double post.....dim to the left and brights to the right. Both ideas would work fine....
  24. tooljunkie
    tooljunkie
    from manitoba
    a single relay,normally closed circuit for low beams,when energized switches to high,one regular relay,one regular toggle switch.
  25. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Speedway sells a low and a high beam switch,Who needs a dimmer for dash lights,,,Thats my opinion ,,,,,I hope thats what you need it for,Im not trying to be a smart ass.......
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That would be an On-ON switch. It will have 3 terminals. The center terminal is power from the headlight switch when on. The outer terminals will be used for the headlights. All floor switches work in this manner.
  27. VoodooTwin
    VoodooTwin
    from Noo Yawk
    I use a Clapper......:p
  28. Belchfire8
    Belchfire8
    Just used a regular floor dimmer switch on the dash in my '40 Ford P.U.
  29. rusty rocket
    rusty rocket
    Speedway and socal sell a 4 position switch off,park,low and high.
  30. i hate the ones on the steering columns...my foot can't reach up that high.:D
