very low model a tudor sedan help?
Discussion in 'The Hokey Ass Message Board' started by snopeks garage, Dec 20, 2012.
  1. snopeks garage
    snopeks garage
    from macomb MI
    low like 5-6 in of the ground. i need a rear end and want a 9in but dont know what size to get or from what car/truck please help, thanks
  2. FlynBrian
    FlynBrian
    Need more specifics on where you want your 'A's rear wheels to sit, what's the backspacing on the wheels your using, how much clearance you want between the wheel/tire combo your using, and the fenderwell? 52pig is right, there are "9"inch width charts on here.
  3. snopeks garage
    snopeks garage
    from macomb MI
    3.25 back spacing i want tire to body gap to be very minimal. running 7.50X16 tires 31in tall.
  4. brandon
    brandon
    Going to say around 61".....
  5. metal man
    metal man
    Also consider if you will be using stock wheel wells. If you make them vertical,as opposed to the angle Ford used to create back seat passenger room, you can use a rear that is about 3" narrower. I have an 8" rear from a '66 Fairlane in my phaeton (same wheel well angle as sedan) because my Maverick rear was way too narrow. The coupes,roadsters, and pickups like a rearend about 56 1/2" to 57" wide, but they have vertical wheel wells. Brandon is right about the 61", if leaving sedan wheel wells.
    What wheel bolt pattern are you using?
  6. verno30
    verno30
    I agree a 61-62" wide rear end is what you need. This rear end is from a 77 or so 1/2 ton Ford pickup. This has the 5 x 5.5 bolt pattern. This car also uses the 7.50-16 tires on the back and has a tight body to tire clearance. Check out the rest of the pics in the albumn.
  7. snopeks garage
    snopeks garage
    from macomb MI
    perfect just what i was asking, thanks! what size wheel and tire up front? i really like that stance. also how hight off the ground are your rockers?
  8. Ester Eddie
    Ester Eddie
    from Alaska
    Did you look at his build thread in his link ?
  9. verno30
    verno30
    5.60-16 front tires
    About 3-3 1/2" of clearance between the lowest point and the ground. THe rockers are not the lowest point.
  10. snopeks garage
    snopeks garage
    from macomb MI
