Vette lug pattern
Discussion in 'The Hokey Ass Message Board' started by DFH-GMC, Jun 11, 2016.
  1. DFH-GMC
    DFH-GMC
    from Texas
    I had to move my vette today and needed 1 rim and tire. So after a trip to the local used parts yard where I got a Chevy rim 5 x 4 3/4.
    I was surprised it didn't fit. For some reason my vette is 5 x 4 1/2
    Front and rear are the same.
    All searches I did came up with a
    4 3/4 lug diamiter
    Am I missing something?
  2. jimmy six
    jimmy six
    I'll bet you didn't get a 4-3/4" from your bone yard..
  3. primed34
    primed34
    Think the newer Chevy wheels are metric so they don't fit the older bolt pattern.
  4. squirrel
    You got the wrong wheel, yours is 4-3/4" measured on the lug circle. If you measure across two studs, it will measure 4-1/2", while the circle is 4-3/4"
    You might have got a 5" bolt circle wheel from a full size car from 71-up.
  5. NMCarNut
    NMCarNut
    You sure you bought a 5 on 4-3/4 wheel or could it be a 5 on 5 wheel? Your measurement looks like a 5 on 4-3/4 hub, not 4-1/2. Check the measuring chart below:
  6. Rick S
    Rick S
    I also don't think you got the correct bolt pattern wheel from the bone yard. Measure again, 5 x 4.75 is correct.
  7. DFH-GMC
    DFH-GMC
    from Texas
    This is what I got
    I think it is a Chevy rally wheel
  8. DFH-GMC
    DFH-GMC
    from Texas
  9. DFH-GMC
    DFH-GMC
    from Texas
    Ok I got it thanks
  10. i think that wheel was used on pickups.....which more than likely are 5" bolt circle
    belair and Hnstray like this.
  11. 49ratfink
    49ratfink
    only the threads on the wheel studs are metric. they used the same 5 lug bolt pattern since 1949 other than the big Caprices and such but they were 5'' as stated
    Hnstray likes this.
  12. 49ratfink
    49ratfink
    I think you are just not putting the wheel on right.
  13. squirrel
    that is a truck wheel, 5" bolt circle, it will not fit a Vette.
    OLSKOOL32, Hnstray and big duece like this.
  14. NMCarNut
    NMCarNut
  15. c-10 simplex
    c-10 simplex
    Ditto; 1/2 ton truck or van rim.
  16. OLDSMAN
    OLDSMAN
    That is definetly a pick-up wheel 5 on 5 pattern not 5 on 4 3/4
  17. wbrw32
    wbrw32
    Why does everyone find it so damn hard to figure a bolt circle??? Did everyone forget what a "Circle" is?? Look at the drawing provided by NMcarnut above...he has drawn a "circle"thru the center of lug bolts..His "C" measurement should be measured from one lug bolt STRAIGHT across to centerline
    of drawn circle...not to another lugbolt.....Now just how hard is that? Been doing it that way for over 60
    years
    1956 F100 and Andy like this.
  18. nmpontiac
    nmpontiac
    from Taos, NM
    I've got a card in my wallet that has the correct measurements drawn out as shown in NMCarNut's post that Red Greth gave me.... I've also got one from Sonny's Automotive that has the same info. Been helpful several times.
  19. manyolcars
    manyolcars
    Right! Also fits Cadillacs
  20. Next time you measure go from the center of a stud, skip a stud, then go to the far edge (not the center) of the next stud. And yes, that's a 5" truck wheel.
    Hnstray likes this.
  21. RainierHooker
    RainierHooker
    from Tacoma, WA
    And Some Buick, Olds, and Pontiac...
  22. squirrel
    It'll fit my car trailer also, but it's still a Chevy truck wheel.
    bobkatrods and Hnstray like this.
  23. ROBRAM
    ROBRAM
    Exactly! That is how you measure a bolt pattern!
    Groucho likes this.
  24. Ebbsspeed
    Ebbsspeed
    His "C" measurement shows the distance between alternate stud centerlines, and matches the chart below the drawing. If there were a "D" measurement which was done as you described, measuring from the center of one stud straight across to the centerline of the circle, it would measure the actual diameter of the bolt pattern (5" in this case). So a 4.755 inch measurement between alternate lug centerlines is indeed a 5" bolt pattern. It's easier to discern the center point of a lug than it is to determine where that imaginary arc of the circle is midway between two lugs. That's why most people measure like the chart shows, vs what you describe.
    Hnstray likes this.
  25. wbrw32
    wbrw32
    [QUOTE="Ebbsspeed, post: 11565616, member: 9560". It's easier to discern the center point of a lug than it is to determine where that imaginary arc of the circle is midway between two lugs. That's why most people measure like the chart shows, vs what you describe.[/QUOTE
    Most people CAN tell where the 'imaginary"circle is At least one with common sense..Hell,I forgot this is 2016 and schools aren't what they used to be..Where they actually teach..
  26. i was just at work and saw that same exact wheel on a customer's Chevy pickup
  27. 283john
    283john
    Since we're all here, how about a pic of the 'vette?
  28. DFH-GMC
    DFH-GMC
    from Texas
    Best I got right now.
    Last driven 1981
  29. DFH-GMC
    DFH-GMC
    from Texas
    To the gentleman that disparaged my education I have no problem understanding how to measure.
    I was told incorrectly a long time ago, yesterday was the first time I had to use this information and I was wrong, now I know and will get the correct rim.
    I proudly graduated in the middle of my cl*** of 1971 from MCHS home of The Battling Bathers
  30. elgringo71
    elgringo71
    How long have you owned the Corvette and what are your plans for it?
