Hot Rods VIDEO - D.W. vs. 'The Dyno'
Discussion in 'The Hokey Ass Message Board' started by BLAKE, Aug 15, 2009.
  1. BLAKE
    BLAKE
    DW, BUZZARD, and a few local geniuses got together last Saturday to tinker a bit with DW's tune... I didn't make it, but my camcorder and tripod did.
    A quick tease...
  2. Kerry
    Kerry
    Now that is cool!
  3. zman
    zman
    from Garner, NC
    very very cool.... it's gonna be a good one this year.
  4. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
    What did it make?
  5. I SMELL SMOKE
    I SMELL SMOKE
    music to my ears!! bad to the bone!!!!!!!!!
  6. Hubbcat
    Hubbcat
    from Sweden
    f**ng awsome.
  7. D.W.
    D.W.
    from Austin Tx.
    This thing has fine manners on the street but I'm looking to set it on KILL for the track.
    Unfortunately, we killed the O2 sensor on the second pull so w/ no lambda readings from the machine, we were left to read plugs for jetting & timing.
    We were able to find optimal timing but we believe we hit the ceiling on the fuel pump. After repeated jetting to try to keep her fat, we just couldn't feed her. Not suprising though.....13.77 lbs. of boost w/ a 110 gph mech. fuel pump....yeah right!
    That said, we only pulled it to 5900rpm. I always shift near 7000.
    At the end of the day we realized 476.61hp / 429.08 torque @ 5900. It was still climbing w/ no signs of dropping off & I don't run out of cam till 6500. We just didn't feel safe taking it to 7K w/o a genuine air/fuel reading.
    We will go back & try again to sneak up on it a little further. I put a larger fuel pump on it so I feel a little better about beating on it @ the HAMB drags. We aren't done tuning but we are headed in the right direction & we learned lots. There is definatly more power there, we just gotta throw more gas @ it to find it.
    Our good buddy Phil Clarkson @ Auto Tek here in town was most gracious lending us his time & his skills. Thanks again man. If any of you local guys want to go faster, go see Phil. He will take good care of you.
  8. TexasHardcore
    TexasHardcore
    from Austin-ish
    God damn that ****ing rules!
  9. D.W.
    D.W.
    from Austin Tx.
    Heres a look @ some squiggly lines.........
      245.6 KB
  10. Glen
    Glen
    Awesome....I love that picture from last year with the wheels up and the grit in your face as it pulled.
  11. Royalshifter
    Royalshifter
    Moderator
    Hot dammmm that was bad***!!!!
  12. flamedabone
    flamedabone
    Hmmm...very interesting...What is your compression ratio, and what is your optimum total timing??
    I'm looking forward to drinking beer and picking your brain for some new found dyno knowledge.
    *** kicking video by teh way. -Abone.
  13. JRussell
    JRussell
    wow that was rad! what broke at the very end ? a hold down braket?? ahhhhh I tought youre gang was the yoo-hoo's
  14. flamedabone
    flamedabone
    You mean this one???
    I love that shot..
    -Abone.
  15. Glen
    Glen
    yep
  16. TexasHardcore
    TexasHardcore
    from Austin-ish
    Looks like Mr Bean Driving. hahaha
  17. D.W.
    D.W.
    from Austin Tx.
    Mr.Bean hahaha!!!!!!!!
    Hey Jeff, I had her locked out @ 36 but I pulled 4 deg. & it made more power......too a point, & then we started running out of fuel so........again, I need to feed it more gas & then see how much more advance I can give it w/o detonation.
    More gas to keep up w/ the boost will certainly help. As for timing, we are always taught that "blowers love advance", but I'm learning that as you spin it tighter, its good to pull some away w/ boost.
    I run a msd boost timing master & while it does work, it is not so subtle or precise. It will retard ign. timing....x deg. per lb. of boost, up to 15 degrees. All fine & good but @ 14-15 lbs of boost, I don't think I wanna retard it that much.
    We played w/ setting the btm knob on .5 & it didn't do **** as far as moving the timing mark/blueline on the ground electrode of the plug. May be I can apply pressure to the msd btm w/ a handheld pressure gauge & check it w/ a timing light to see just how finely adjustable it is or not.
    Will I need to take the ign. timing back up to 36 or more after I can get it more fuel? I dunno, maybe. I'll just have to tinker more & see.
  18. D.W.
    D.W.
    from Austin Tx.
    Oh yeah Jeff........8.25 static
    Hey Joe.......where ya going w/ that .........oh, I mean, I think thats just some paper flying around
    Maybe soon, Blake & I can edit more footage together, we've got lots.
  19. 54BOMB
    54BOMB
    Rad, Im glad you got some dyno time, I cant wait to see that monster run this weekend.
  20. buzzard
    buzzard
    Alliance Member
    More fuel, and better fuel. I still think that you were held back by the gas you had in there. Bump up the fuel volume and octane, and give it a few more degrees in timing. Free horsepower.
    Tell 'em about the hats.
  21. D.W.
    D.W.
    from Austin Tx.
    Yeah, we were running Vp c12 w/ a motor octane of 108 (ron118). Perhaps when we find what seems to be the limit, we can feed it more octane & timing? Hmmm......
    About the hats/air scoops...........I'm running some cal-custom 40-40's & they look kick *** (I think)
    During the course of tuning, we found a considerable increase in hp/torque by removing these from the carbs. This simple change alone found............
    ..........wait for it..........................................
    76 horsepower!
    With the restriction removed, boost climbed from 12.58psi to 13.77psi & we started to run outta gas.
  22. 54BOMB
    54BOMB
  23. swade41
    swade41
    from Buffalo,NY
    What do they say about the price to look cool ???
    For 76 ponies I'd trade them out for the track runs that's for sure.
  24. flamedabone
    flamedabone
    Please explain....hats...Do you have a pic?
    -Abone.
  25. good golly.
  26. D.W.
    D.W.
    from Austin Tx.
    Glad you are gonna make it to the drags again this year Brett.
    Silly little air scoops...................
  27. Tudor
    Tudor
    from GA
    Kick *** dw. I have those same scoops on mine. They do look killer! Maybe when you are doing 120 they don't kill the power. Thanks for sharing. Have fun at the drags. Can't wait to hear what u and abone turn. Kerry too.
  28. sawzall
    sawzall
    damn 76hp MORE without those scoops..! I'd throw them in the trash..
  29. Big Tony
    Big Tony
    Kewl...good luck in Mokan...gonna need a video of that for the poor idiots like me that will not make it
  30. Tudor
    Tudor
    from GA
    Oh yeah this is exactly why the small chev RULES.
