Hot Rods VIN decoder for classic cars
Discussion in 'The Hokey Ass Message Board' started by Merc cruzer, Oct 17, 2015.
  1. Merc cruzer
    Merc cruzer
    from Colorado
    Is there a VIN decoder app for cl***ic cars for smart phones. This would be helpful when you are at an auction looking at cars.
  2. spooler41
    spooler41
    Any numbers prior to 1968 will be basically serial numbers, and they don't
    tell you very much.
    Good luck!
    ......................................... Jack
  3. Everyone did more or less their own thing until the late 1960s or so, it would be hard to make one ap to encomp*** everything. And as mentioned most serial numbers don't give you a lot of information - or even the same information when they do have some in it. Late 50s Pontiac will tell you model year, build plant, and manual or auto trans. Early 50s Chevy will tell you which model series it is and I think build plant. Some older serials are all numbers and all you get is model year from it.
  4. Merc cruzer
    Merc cruzer
    from Colorado
    We are current looking to add a 1956 Ford Victoria two door and this is what I am using on my phone. I have a made up vin tag to use if you want yo try it.
    Type in:
    M6PV 12003
    64C NE BG 5L5059D
    http://vinmagic.com/1956-ford-vin-decoder/
    1956 Ford
    VIN: M6PV118538
    Engine Code M V8 292 ci OHV - 4V Carb. (200hp MT, 202hp AT)
    Production Year 6 1956
    ***embly Plant P Twin Cities, MN
    Body Style V Tudor Victoria
    Production Sequence 118538 118538
    Data Plate Information:
    Body Type 64C Fairlane Victoria
    Paint Color Code NE Mandarin Orange with Colonial White
    Interior Trim Code BG White and Orange Vinyl
    Production Code 5L4048D November 5, 1955
  5. HOTRODPRIMER
    HOTRODPRIMER
    I don't know diddly squat about apps but I know the vin numbers on '54 Fords will tell you all about your car.
    This was posted on the '54 Ford Club of America website but the clubs founder and past president,Tom Hoskins. HRP
    volvobrynk likes this.
  6. Vintage Ford serial numbers (or what would be considered the 'VIN' these days) as such only give you limited information; year, body type, ***embly plant, and engine. This was true for Fords until somewhere in the 70s. The data (or 'patent') plate is where the real info is but these can turn up missing, particularly the ones mounted on the doors as Ford typically did in the 60s and 70s. HRP's example above is still missing some key info; axle ratio and trans type was added in later years. These still don't always reflect possible options, for that you need the build sheet.
  7. SR100
    SR100
    When I try it from my browser, I get this error:
    "Unable to decode VIN. Please check the number and try again.
    1956 Ford VIN should look like M6GW100001"
  8. spooler41
    spooler41
    I believe that the federally mandated VIN numbers are a 16 digit number/letter code
    that was started in 1968. Before 1968 serial numbers and body tags were a manufactures
    own system, not a universal system covering all manufactures.
