Hot Rods Vin number problems on a sbc
Discussion in 'The Hokey Ass Message Board' started by 32highboy54, Jan 4, 2015.
  1. 32highboy54
    32highboy54
    from southport
    Hey guys I just pickup a 55 chevy with a 350 chevy. I was trying get the year off the block but i cant find a vin number that will match this engine. The number stamped on the front of the front of the block is v0819cnv. Any help. Thanks
  2. saltflats
    saltflats
    from Missouri
    CNV comes up as a 1970 350 / 250 H/P L65 out of an Imp
  3. 32highboy54
    32highboy54
    from southport
    thanks for the info. I didnt know what the CNV stood for
  4. squirrel
    that's the "suffix code" which you can look up in a book, or on the internets.
  5. 56 Dodge Pickup
    56 Dodge Pickup
    where did you find the number on the block I found a number on the drivers side by the bell housing 3970010 maybe I'm missing something Jim
  6. manyolcars
    manyolcars
    thats a standard casting number
  7. Slopok
    Slopok
    P***enger side right below the head.
  8. manyolcars
    manyolcars
    1970 Caprice, What is an Imp?
  9. 56 Dodge Pickup
    56 Dodge Pickup
    Thanks Slopok I will be working on the motor mounts this week I will look for the number would love to have some more info on this motor. Jim
  10. Slopok
    Slopok
    OK let us know what you find out.
  11. squirrel
    Impala? the Caprice's cheaper brother.
  12. CrazyVern
    CrazyVern
    I have seen the serial number stamped on the oil filter area on some sbc but not all. It have been a little hard to see if the casting is rough.
  13. 56 Dodge Pickup
    56 Dodge Pickup
    OK I have finally removed the engine plate and installed new motor mounts the block numbers on the pad below the p***enger side head are 7713009695 /0103C2R The block casting divers side bell housing is 3970010. Thank you in advance for any information. Jim
  14. squirrel
    interesting,
    C2R 1982 305 155 4 Roch E4ME carb.
    but the block casting number is 69-79 350. The 7713.... number looks funny, it should be one less digit, and probably have a letter or two in it, and not start with 7.
    so my guess is the numbers are not quite what they appear (they can be hard to read), and it's just another old 350.
  15. 56 Dodge Pickup
    56 Dodge Pickup
    Thanks Squirrel I will check again have a Great Day! Jim
