Projects Vinegar..... It really works
Discussion in 'The Hokey Ass Message Board' started by Crystal Blue, Dec 30, 2011.
  1. Crystal Blue
    Crystal Blue
    O/T project, but you get the idea.
    Added the vinegar to a poly 55gal. drum cut in 1/2.
    14 days later. Scrubbed with a S/S brush, then washed it with a mixture
    of baking soda and water. Dried it with a heat gun.
    Note the flash rush. Sprayed it with One Step. The clear spray
    converted the flash into a black coating.
    On to final prime and paint.
    Hope this helps.
  2. Yup, tried vinegar, it works. Now I`m trying a mol***es bath on my brake drums to compare . Lots of great stuff on here in the archives
  3. Jalopy Joker
    Jalopy Joker
    yep, good info/tech - looks like in first pic that there is a pilot bushing - would make a "killer" engine fan (Ha!). where did you find the One Step?. have not seen that before.
  4. Sledge
    Sledge
    from Nor Cal
    Looks like a giant Chinese throwing star. Thanks for the info!
  5. Crystal Blue
    Crystal Blue
  6. That bolt-on has to be something off the farm .... looks wicked!
    Make sure its "white" vinegar ... it also works well in the place of "Metal Etch" (like Jasco) when prepping sheetmetal.
    ....and a teas**** a day in 12 ounces of water keeps the beer-gut under control LOL
  7. fullthrottle53
    fullthrottle53
    That part looks like it came off of some corn binder. Do you want to sell it? I need a new steering wheel for my car! LOL
  8. bobwop
    bobwop
    from Arley, AL
  9. stealthcruiser
    stealthcruiser
    Who you callin' a hoe? :D
  10. Pat Pryor
    Pat Pryor
    its good to run thorugh an old engine also. clean out the ****. and wash your windows better then most cleaners.
  11. Steve Ray
    Steve Ray
    I thought it looked better before you derusted it.
  12. Mopar Jack
    Mopar Jack
  13. ChefMike
    ChefMike
    Very Cool I was wondering if that worked ? Looks like it did cant wait to try it
  14. koolkemp
    koolkemp
    Did you cut the vinegar with water or use it straight?
  15. PinHead
    PinHead
    You mean a Hoe that goes around? Don't they all?
  16. BISHOP
    BISHOP
    ****anny cleaner too, or some call it YippeeBog, Squish Mitten, Oyster Ditch, Ham Wallet, ***** Wrinkle, Fiddle Cove, Pudding Hatch, Or just *****.
  17. RAG66
    RAG66
    from WASHINGTON
  18. sfort
    sfort
    from texas
    Spinner!
  19. B.A.KING
    B.A.KING
    jeez you guys, everybody know that is a steeringwheel for a ratrod......whooooops:D
  20. BLUDICE
    BLUDICE
    I'm a believer - bought a pair of old hub caps - after markets creap grade SS - covered with rust - so I used rubbing compound, Mothers, steel wool on one, and soaked the other in vinegar. The one I tried to rubbed out looks like s@#^, but the one I soaked looks almost like new.
  21. Goes with the switchblade shift knob
  22. hot rod rod
    hot rod rod
    Pur,t,, !!! 1/2 cam bud in... will really give it that finish !!!! Oh Yeh !!!, Have A Happii Big One !!!!
  23. hot rod rod
    hot rod rod
    Maybe It Is !!!
  24. Crystal Blue
    Crystal Blue
    Straight out of the bottle. It took 2 1/2 gallons to cover the part.
    As a side note, there was no heat on in my shop. Temp was about
    50 degrees F, and the tub was not covered.
    My brother stopped over tonight. We checked the ph of unused vinegar.
    It registered 6.0. The used vinegar after 14 days and contaminated with
    rust registered @ 5.9ph (So the **** is still good)
  25. Crystal Blue
    Crystal Blue
    I guess you'ld have to see it in person :rolleyes:
  26. lowkroozer
    lowkroozer
    That isn't a rat rod steering wheel.It is a spur for a big *** cowboy !
  27. fordcragar
    fordcragar
    from Yakima WA.
    I have the same vinegar that has been in a plastic tank for the last 10 years. When the level goes down I just add to it.
    Usually I just soak the part for about 3-4 days and pull it out and hose it off with a good high spray of water. The rust washes off in sheets. If there is still rust on the part, it will go back into the vinegar for a couple of more days. After that the part is washed with soap and water; which neutralizes the acid. Then you can prime and paint.
    The first time I tried the vinegar, I soaked the parts for 3 days and pulled the parts out and all the rust seemed to still be there. So I put them back into the vinegar for a week this time. Then I checked them again and they were still rusty, and I thought that this ****ed. So I grabbed the hose to wash the parts and look for another method to get rid of the rust. When the hose spray hit the parts the rust came off in sheets. So that is how I got the the heavy rinse.
