Hot Rods vintage grease nipple
Discussion in 'The Hokey Ass Message Board' started by john walker, Dec 29, 2016.
  1. john walker
    john walker
    What kind of grease gun was used on this type of ******? Later ******s have a knob on the end that the gun clips onto. I replaced several that could be unscrewed, but they are integral on the spring bushings on my '33 chrysler.
  2. loudbang likes this.
  3. 56shoebox
    56shoebox
    ****** and knob used in the same sentence. LOL!!! My 12 year old sense of humor.
  4. noboD
    noboD
    My '29 Dodge brothers has those. The gun is a push type, not very effective. Don't throw them away but replace with real fittings.
  5. squirrel
    can't you just use a needle for that?
  6. john walker
    john walker
    Never thought of that.
  7. Yes.
  8. woodiewagon46
    woodiewagon46
    from New York
    Model A Ford used this type. They do make an adapter from a modern grease gun.
  9. hotroddon
    hotroddon
  10. mike bowling
    mike bowling
    Any Model A place-Mac's, Snyder's, Tam's all carry the adapter
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    But em all together and..... OUCH !
    squirrel likes this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Have one. It makes putting grease in a leaky steering box so much easier.
  13. Rusty O'Toole
    Rusty O'Toole
    That is for an oil gun not a grease gun. Made to be lubricated with heavy oil. There is an oil gun to lubricate them. It pushes against the fitting, it does not lock on. The end of the grease gun is spring loaded and telescopes into itself applying the correct pressure when you push on it.
  14. Texas Webb
    Texas Webb
    That p***es the pencil test:D.
  15. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    That certainly is a fine example.
  16. john walker
    john walker
    Great, thanks. Any particular oil gun?
  17. winduptoy
    winduptoy
    Adapter, Needle Tip
    Part Number: 05-042
    UPC Number: 028893050421
    • For chain saws, universal joints, bicycles. Etc. For hand operated grease guns only.
    For more information about this product, Plews & Edlemann
    Please Contact Us, or call us at 800-545-1689
    Dispenser, Needle Nose
    Part Number: 05-045
    UPC Number: 028893050452
    • Dispenses a fine line of grease through needle nose. 3/4" adapter with 1/8" femail NPT. Use with extension or hose. 19/32" needle length. .046" tip diameter and .219" body diameter. For hand operated grease guns only.
    Grease is oil bound up in soap. For the type of grease fitting you depicted (your ***le got attention)
    I've found it difficult to get lube into the fitting and where it eventually needs to go, with out using an accessory like one of these. If you get the first one you need to get a good high pressure coupler or you get a mess.
    Good luck,
    Larry
    Check out the Plews & Edlemann site
  18. Oh sorry, I thought this was going to be another Jungle Pam thread. As you were.
    Stogy likes this.
  19. BJR
    BJR
    That fitting is called an Alemite fitting.
  20. tb33anda3rd
    tb33anda3rd
