Technical Vintage Hurst shifter??
Discussion in 'The Hokey Ass Message Board' started by out plowing, Jul 2, 2025.
  1. out plowing
    out plowing
    I'am stumped, picked up this older Hurst shifter, it's not a comp series. The only number is 032339 stamped on the shifting cage. It's a 3 speed unit. Any ideas what it fits ???
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Muncie 318 (3 speed) much like this example. Later ones had trans crossmember mount on tail housing. Cut off around 1965 if I remember correctly? IMG_4251.jpeg
    That said, the shifter and mounting hardware will work on later Saginaw 3 speeds (differant shift rods and levers needed).
    porkshop and out plowing like this.
