Vintage mechanical fuel injection pictures
Discussion in 'Traditional Hot Rods' started by longstory1948gmc, Aug 11, 2014.
  1. kidcampbell71
    kidcampbell71
    That truck is sooooooooo perfect. Man, I dig it. No intel on who, what, where, when, or how huh? Nice ride.
  2. longstory1948gmc
    longstory1948gmc
    from n Illinois
    I would too I have a 228 in mine and going to drop in a 383 stroker but if I could find that setup things may change.
  3. teach'm
    teach'm
    from Tucson, AZ
    The pictures aren't very good, but here's a mechanical flathead setup a friend of mine just finished putting together.
    echo ed, jmkporsche, KiWinUS and 3 others like this.
  4. carpok
    carpok
    from Indy
    Sorry I don't have a lot of that info. I do have a shot of a logo on the side of his trailer. And am sure he said he lived in South Dakota. I wish I would have got more info. He had a wealth of info on those motors and heads. If I remember right that truck was running in the 11s. Sounded so bad ***ed wish I would have videoed the run. Ron
    Deuces and Hank37 like this.
  5. carpok
    carpok
    from Indy
    I just found this utubeVideo sure looks like the same truck.
    Deuces likes this.
  6. RichFox
    RichFox
    It appears to be a late model (292) Chevy with a Sissel-Duggan head and injection. Available new from Sissel.
  7. carothersbs
    carothersbs
    Question: is running a mechanical hillborn setup in any way streetable, or more for a track only?
    Looking into running it on a single seater lakerster style car on a 59A block.
    Ive only see hillborn setups on drag cars and such. Probably for a reason.
  8. DDDenny
    upload_2020-10-22_15-48-20.png Yup, EFI
    HAMB'r Brian Kohlmann
    racer-x, enloe and Deuces like this.
  9.
  10. I took this from a genius on ebay many yrs ago-- I think the ad said "modified for a carburetor" or something stupid.
    Deuces likes this.
  11. X38
    X38
    What does this mean? Guy is asking about mechanical.
    carothersbs likes this.
  12. jimmy six
    jimmy six
    The ever popular Skinner Fuel Injection on a Skinner GMC 12 port Cylinder head. 8D1C4688-3D88-409F-8B29-6781D1CE6A78.jpeg
    KiWinUS and Deuces like this.
  13. 6sally6
    6sally6
    Help me out here............Do you need to prime mechanical fuel injection before it will crank?! How you do dat with a street rod?
    6sally6
  14. Marty Strode
    Marty Strode
    2-1/16 Hilborn , 10" stacks, 7A nozzles, set up for gasoline. IMG_4928.JPG
  15. jimmy six
    jimmy six
    If you have fuel right at the barrel valve by putting the fuel shut off right before it, open the shut off, open the throttle foot feed, crank the engine a few seconds, the fuel will enter the intake like an accelerator pump. Then close the foot feed turn on the ignition and hit the started ****on. This is an acquired skill.
  16. nochop
    nochop
    from norcal
    My dads club rail late 50s early 1960 8C77EA11-92F8-4141-B5FB-D90449DE91BE.jpeg
  17. grdra1
    grdra1
    A few pics of a crower 8 hole on my topolino. Glen 100_1274.jpg 100_1279.jpg PC010241.JPG PA240100.JPG
  18. pnevells
    pnevells
    Vintage Crower injector updated with Kinsler nozzles and pump
    echo ed, racer-x, 72yenkonova and 3 others like this.
  19. ratrodrodder
    ratrodrodder
    from Boston
  20. pnevells
    pnevells
    newer pic of our Crower injection
    72yenkonova, KiWinUS and Deuces like this.
  21. tpw35
    tpw35
  22. My son's '31 Model A.......1st model Hilborn injector for SBCs..........
    Hollywood-East, Deuces and KiWinUS like this.
  23. Deuces
    Deuces
  24. Scott Mize
    Scott Mize
  25. chasmalo
    chasmalo
    I understand they can converted to EFI which would make driveability a whole bunch better.
    Chas
    Sent from my SM-G950U using Tapatalk
  26. Please help me understand this, these systems use a high pressure fuel pump to deliver fuel to a control valve that is connected to the throttle pedal? Then, from the control valve, fuel goes to each stack? Are there throttle ****erflies in each stack? If this is the case, they are also controlled by the same linkage as the control valve? How much pressure is delivered by the fuel pump? Does this pump also act as the delivery pump from the tank, or does it use a separate pump for this. Sorry for all of the questions, I’ve never been around this type of injection. Being a diesel mechanic, I know all about that type of injection, but this is all new for me. Thanks for the help.
    Andy
  27. X38
    X38
    Which would be off topic to discuss here.;)
  28. Scott Mize
    Scott Mize
    There are two valves which control the fuel. The first valve is a supply shut off valve which typically is mounted on top of the metering distribution block. Within the distribution block is another valve which is connected to the accelerator and the ****erflies. This valve is used to meter the fuel to the distribution block and controls the lean/rich fuel mixture.
    Deuces and Truckdoctor Andy like this.
  29. sunbeam
    sunbeam
    They are converted to injectors like new units Bosch used a system that used a O2 sensor to control the spill valve. I have often wondered why someone would have used this in a mod for constant flow units. Units like can be tuned to to idle well and work for full throttle. Its part throttle load sensing that they fall down on with a wide sensing O2 sensor they could be very streetable and still keep the look. We have alternators that look like generators and electronic ignitons that looks like a mag.
  30. Scott Mize
    Scott Mize
    Here a photo of what I described earlier.
    Sent from my iPhone using H.A.M.B. View attachment 4855943
