Features Vintage Multiple Carb Intake Pictures
Discussion in 'Traditional Hot Rods' started by PKap, Feb 9, 2013.
  1. Mr cheater
    Mr cheater
    Don't. Know if this fits here but here's my 2 2 intake for my f100
    Sent from my DROID device using the TJJ mobile app
  2. cs39ford
    cs39ford
    This is what I run on mine
      92.5 KB
    enloe likes this.
  3. Bought this off a HAMBer to put on my 331 Caddy - I like it!
    ls1yj and bruce bowe like this.
  4. joburnsjo
    joburnsjo
    Her's a couple of mine
  5. bjinx
    bjinx
    Like the air cleaner, took me a minute to snap to what it is made of.
    I also have a very early Offenhauser intake with the port at the drivers side rear. What is the hose you have hooked to it? I thought it was for a mechanical temp sender when used on the early 265ci chevy motors.
  6. timwhit
    timwhit
    Sweet!!!
  7. early olds stuff
      60.4 KB
      221.2 KB
    ls1yj likes this.
  8. Mat Thrasher
    Mat Thrasher
    This ones mine. It's a homebuilt set-up except I used a dart single plane intake to build off of. With it being a BBC I didn't want to get into locating the distributor. It actually performs really well both cruising and wot. Also I'm running large base 2g's with progressive linkage. I tried it both straight and progressive. I found that progressive with the secondaries opening as quickly as possible off of cruising speed gave me the best mix between throttle response and drivability.
  9. Mat Thrasher
    Mat Thrasher
    Opps this ones mine the pic didn't post.
  10. titus
    titus
    My obssesion is buying bare intakes, collecting up carbs and air cleaners and linkage and making complete set ups. heres a few pics of some of my stuff.
    and also a couple pics of some cool vintage engines in hot rods
  11. PKap
    PKap
    from Alberta
    Cool obsession. Question on the setups running two rows of carbs. Do you run one carb on each side as a primary with a choke? Do they all need a choke if they are not running a progressive linkage?
  12. titus
    titus
    Usually one center in each row is set and the primary carb and then the out 4 are the secondary like a 3x2 set up, and just chokes in the middle carbs.
    jeff
  13. hyperfe
    hyperfe
    Stromberg 97's from Clive
  14. Halfdozen
    Halfdozen
    Probably ten or twelve years ago I was wandering the swap meet at Goodguys Indy and saw a homemade 2x2 intake that looked like it might be for a Plymouth flathead six. I think the carbs were Carters, the builder had split the throttle shafts between the ****erflies and built a really nice linkage setup using a bunch of little br*** bits, so that each carb operated progressively. Thought that was a great idea. It was grubby and gas- stained, so it obviously had been run. I'd like to try building something like that myself sometime.
  15. fast30coupe
    fast30coupe
    from Illinois
  16. Is it possible to OVER-CARB a Flathead? LOL!!!!
  17. lockwoodkustoms
    lockwoodkustoms
    Something I am putting together for my 39
  18. raprap
    raprap
    from Ohio
    Here's my current set up. 3 x 2 Holley/Weber 5200's on an Offy Intake.
    The other photos show a 5-Carb intake I designed and built about 5 years ago. Had 5-94's and velocity stacks ready to bolt on but a buddy saw it and he just had to have it. Good thing because I really did not want to cut a slot in my hood!
  19. 296 V8
    296 V8
    from Nor~Cal
    Iv seen one running 4 Rochester’s :cool:
  20. R W Ohio
    R W Ohio
    from Ohio
    This is what we ran in 1972
    HarryT and 6inarow like this.
  21. SIX GUN
    SIX GUN
    This is off of an old H/MP car from the 70's
    6inarow likes this.
  22. OoltewahSpeedShop
    OoltewahSpeedShop
    A few I've had over the years.
  23. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Nothing special, and not homemade, but it's multi....
  24. PKap
    PKap
    from Alberta
    The two different straight six intakes you posted, did the version with the carbs running into separate ports run better than the one that had the tied together runner? Just thinking that the intake vacuum would be identical on each carb as each intake port has equal volume. In contrast, is the balance tube better in that it integrally balances out the flow differences between the different carbs?
    Thanks for any thoughts on pros/cons
  25. lockwoodkustoms
    lockwoodkustoms
    My 39 finally has them on it and that is Howie laying down some lines at the show.
  26. Kerry
    Kerry
    I ran this a while before I switched to a 6/71 and a pair of Pontiac AFB's. Worked great!
  27. 550Coupe
    550Coupe
    My two Olds engines.
      501.2 KB
      436.1 KB
  28. Abomination
    Abomination
  29. sidevalve8ba
    sidevalve8ba
  30. OoltewahSpeedShop
    OoltewahSpeedShop
    I honestly don't know. I built this stuff for someone else and as far as I know, none of it has ever seen the road....
    I would ***ume the plenum style intake that was built similar to the old McGurk, would be more user friendly. The individual carb per intake runner would probably need some sort of balance tube between them to make it happy.
    Just guessing though.... :rolleyes:
