  1. philo426
    philo426
  2. plym_46
    plym_46
    from central NY
    Any body recognize the device mounted to the pole above the cash register????
  3. Cat and friend Lula Mae, a very lovely friend at that. Sure do miss her.
  4. jalopy junkie
    jalopy junkie
    .....Holly Golightly
  5. mart3406
    mart3406
    from Canada
    A 4-wheel-drive, amphibious Volkswagen
    type 166 "[FONT=verdana,arial,sans-serif][SIZE=-1]Schwimmwagen"[/SIZE][/FONT]
    version of the WWII German VW
    "Kubelwagen" bucket car,
    which was itself the forunner and
    predecessor of the VW-based "Dune
    Buggies of the 1960;s and 70's! I
    want a "Schwimmwagen"!!:D
    Mart3406
    "[FONT=verdana,arial,sans-serif][SIZE=-1]Schwimmwagen"[/SIZE][/FONT] Specs.
    (from Wikipedia)
    Manufacturer Volkswagen
    Production 14,265 (1942-1944)
    Engine 4-cyl. boxer, air cooled
    1,131 cc, 25 hp @ 3,000 rpm
    Transmission 4-speed manual
    2-speed transfer case;
    4WD only on 1st gear / reverse
    Wheelbase 200 cm (78.7 in)
    Length 382.5 cm (150.6 in)
    Width 148 cm (58.3 in)
    Height 161.5 cm (63.6 in)
    Curb weight 910 kg (1,345 kg GVW)
    Related VW type 86 & 87
    An article on the German
    Schwimmwagen from the
    Dec. 1944 issue of the
    Intelligence Bulletin.
    http://www.lonesentry.com/articles/schwimmwagen/index.html
    "The German light amphibious
    car, which resembles a small
    civilian sports car and has a
    boat-shaped open body, is highly
    maneuverable. The Germans call
    this vehicle a Schwimmwagen,
    literally enough, while on the
    Allied side it sometimes is spoken
    of as an amphibious Volkswagen.
    The light amphibious car represents
    a development of the original
    Volkswagen ("Peoples Car"), a light
    civilian vehicle that Hitler once
    promised to manufacture in huge
    quantities and bragged about as
    one of the future blessings of
    German National Socialism.
    The light amphibious car has the
    following dimensions:
    Over-all length (with propulsion
    unit in land-travel position) 11 ft. 8 in.
    Over-all width - 4 ft. 10 in.
    Over-all height (with top
    up) 5 ft. 2 in.
    Tread width, center line to
    cente.r line 4 ft.
    Wheel base 78 in.
    Ground clearance (unloaded)
    11.5 in.
    Approx. depth of immersion
    when floating 2 ft. 6 in.
    Freeboard (loaded) 13 in.
    The following details have obtained
    from a manufacturers plate in the
    engine compartment of a car which
    was examined recently:
    Type 166
    Payload
    958 lb.
    Weight empty
    2,002 lb.
    Permissible axle load (front)
    1,190 lb.
    Permissible axle load (rear)
    1,775 lb.
    Permissible total weight
    2,965 lb.
    Engine capacity
    1,131 cc.
    This specimen was fitted with "run-flat"
    tires, size 7.85 by 16.
    The German Light Amphibious Car
    The engine is of the 4-stroke, 4-cylinder,
    horizontally-opposed, air-cooled type,
    similar to that of the ordinary Volkswagen,
    Model 82, and has a capacity of 1,131 cc.
    When the car is afloat, the crankshaft
    leading through the back of the vehicle
    effects the propulsion. The crankshaft
    ends in teeth which form a dog-clutch,
    which engages either with the propeller
    drive, when the latter is in position, or
    with the starter handle.
    There are four forward gears, and one
    reverse, and also an auxiliary lever for a
    low gear for cross-country driving and for
    engaging or disengaging the 4-wheel drive.
    When the auxiliary lever is in the forward
    (cross-country) position, gear must not be
    changed, according to a warning notice on
    the instrument panel.
    For starting under winter conditions, a
    specially volatile starting fuel is used. This
    is contained in a small auxiliary fuel tank
    with a capacity of about 1 liter, connected
    by a synthetic rubber tube to the fuel pump.
    This auxiliary tank is situated in the engine
    compartment, which is in the rear of the
    vehicle.
    The cooling-fan intake is between the two
    rear seats. A transverse exhaust silencer is
    mounted over the engine compartment,
    and discharges on both sides. The body is
    of pressed steel with welded seams. The
    shaft entrances are made watertight by
    corrugated rubber tubing. An independent
    torsion-bar suspension is employed on each
    of the front wheels.
    When the three-blade propeller unit is not
    in use, it folds over the back of the vehicle.
    This unit is provided with a chain drive to
    a sprocket, the shaft of which is provided
    with teeth which engage with those on the
    crankshaft end. In water, as on land,
    steering is effected by the conventional
    steering wheel, which governs the front
    wheels of the vehicle. When the car is
    traveling through water, the transmission
    is neutral, and the accelerator regulates
    the speed.
    The instrument panel is fitted with
    a switch for speedometer lighting,
    a charging indicator (red), an oil
    indicator lamp (green), a plug for
    the inspection lamp, a speedometer,
    and a combined lamp-and-ignition
    switch. Beneath the instrument panel
    are a gasoline filter, the auxiliary
    fuel pump, and a lever for operating
    the pump for one-shot lubrication.
    The foot controls comprise (from
    left to right) a dimmer switch,
    clutch, foot brake, and accelerator.
    The hand controls are the gear lever,
    a lever for putting the 4-wheel drive
    and the cross-country gear — or
    both — into operation, a small
    lever for operating the choke, and the
    hand-brake."
  6. rainhater1
    rainhater1
    from az
    I think it is a green stamp machine
  7. Novadude55
    Novadude55
    from CA
    before we ever heard the word 'import car'
    yeah,, the good ole days
  8. Deuce Daddy Don
    Deuce Daddy Don
    "immediately":d
  9. hudson48
    hudson48
    Studebaker all crossed up being chased by an FX Holden somewhere in Australia?
  10. walpolla
    walpolla
    Catalina Park near Katoomba, west of Sydney. No longer used as a race circuit. Only parts of the track remain I am told, with the local indigenous people now having posession.
    Anyone else from Australia seen it lately?
    The car behind the Stude. is a 48/215 Holden, more commonly called by its nickname the "FX". Built from 1948 to 53.
    http://en.wikipedia.org/wiki/Catalina_Park
    regards,Rod
  11. Novadude55
    Novadude55
    from CA
  12. Novadude55
    Novadude55
    from CA
    oh yeah, and a 1948 Renault 4CV,, :D
  13. mart3406
    mart3406
    from Canada
    "THE WIERD WORLD OF LSD" movie
    press
    kit photo - circa 1967
    Mart3406
    "THE WIERD WORLD OF LSD".
    Starring Terry Tessem, Ann
    Lindsay, and Robert Jackson.
    DIRECTED BY ROBERT GROUND.
  14. swi66
    swi66
    Ruxton
    Packard
  15. swi66
    swi66
  16. swi66
    swi66
  17. swi66
    swi66
  18. swi66
    swi66
  19. swi66
    swi66
  20. swi66
    swi66
  21. swi66
    swi66
  22. Elvis sitting with the Browns, Jim Ed and sisters.
  23. Breakfast at Tiffany's:)
  24. correct not Neil
    I lived through it
    my shop was on Front St
  25. fremont rugrat
    fremont rugrat
    Is that Arnie Cunningham cruising down the street in Christine? Great shot.
  26. fremont rugrat
    fremont rugrat
    Battleship Turrit?
  27. CamCat
    CamCat
    from France
    Have you seen this photo from the carrier deck?
    kbgreen likes this.
  28. Finn Jensen
    Finn Jensen
    Love this photo. Santa Ana?
  29. gnichols
    gnichols
    from Tampa, FL
    Missed it, but thanx. Another shot for my Navy file. While I was on the Ranger we also did this cool deal with B-25s off San Diego celebrating Dolittle's raid. I posted some pix some place here on the HAMB awhile back. Anywho, we deck launched two B-25's with lots of Warbird flybys ta boot. Some days were funner than others. Gary
    Now that I have my B-26s turned into B-25s, also see: http://navysite.de/cvn/cv61.htm
  30. 231ramona
    231ramona
    I spent many a teenage day cutting and housing tobacco. Not fun.
