  1. SouthUrn
    SouthUrn
    from US
  2. SouthUrn
    SouthUrn
    from US
  3. one2roc
    one2roc
    Wow, what a beauty! :p:p:p
  4. mart3406
    mart3406
    from Canada
    Very cool pic of an early, experimental
    version of the Ford V8! This is probably
    - with a few minor changes - the Flathead
    V8 that Ford *should* have produced!
    Having both the intake and the exhaust
    ports on the inside of the 'Vee", similar
    to what Cadillac, Oakland and others
    did with their flathead V8's - rather
    than having the exhaust p***ages
    going through the block and around
    and between the cylinders :)eek:) and
    exiting on the sides, as Ford ended up
    doing with their eventual production
    V8 - would have by probably greatly
    improved exhaust flow and eliminated
    the chronic overheating problems
    that Flathead Ford V8's ended up
    being somewhat notorious for. One
    potential problem I can see with
    this particular engine, which could
    have been solved by moving and/or
    redesigning the waterpumps - is the
    very close proximity of the exhaust
    manifold at the front of the engine
    to the belt driving the fan and the
    waterpumps - which I think if used
    and put into production "as is", would
    have probably resulted in extremely
    short belt life.:eek:
    Mart3406
  5. khead47
    khead47
    ^^^^Looks like the exhaust still runs between #2 and 3 cylinders! But what could the solenoid looking thingy be hooked to trans-bellhousing be?
  6. 31Dodger
    31Dodger
    I see a starter (above) and what looks to be a vacuum clutch unit (freewheeling)under the manifold. At least, that is what the Chrysler equivalent part looks like.
  7. rainhater1
    rainhater1
    from az
    vac clutch look for the cable
  8. Mart
    Mart
    Yeah, vac ***ist for the clutch. Early 32 firewalls have an indent in for a vac canister that was ***ociated with this clutch ***ist gizmo. It never reached production.
    Mart.
  9. themoose
    themoose
  10. empire
    empire
  11. walpolla
    walpolla
    Brigitte Bardot according to Mr Google.
    Rod
  12. moefuzz
    moefuzz
    I was Banned?
    -That's certainly news to me.
  13. moefuzz
    moefuzz
    .....Photobucket is currently pizzed off at the amount of bandwidth that my account uses so they are limiting the account. An average month used to equal 200 to 300 GIGABYTES of bandwidth with 4 or 5,000,000 views. (a good amount of this was from the HAMB)
    Photobucket has been applying the brakes anywhere from the 15th to the 20th of each month depending on when I hit their wall.
    Once the account hits the wall all pics are restricted until the 1st of the next month irregardless of me being allegedly banned here or anywhere.
    For what it's worth, I did know that the day would come when Photobucket would limit the account over excessive use of bandwidth .
  14. moefuzz
    moefuzz
    Here's one for the road.......
  15. 29bowtie
    29bowtie
    Here's some more 'Vintage Shots" for some of you to enjoy. Hope you like them.
  16. Von MoPar
    Von MoPar
    from Australia
  17. DavidY
    DavidY
    from 15102
    Nice hairy legs!
  18. Brizo
    Brizo
    from Indy
    That's actress Haley Mills wearing hose made with a lace pattern.
  19. 29bowtie
    29bowtie
    "Canadian Vintage Shots from Days Gone By".
  20. DavidY
    DavidY
    from 15102
    A Meteor there on the left?
  21. DavidY
    DavidY
    from 15102
    A Meteor for sure.
  22. monkeyspunk79
    monkeyspunk79
  23. 29bowtie
    29bowtie
    More shots from Canada. Imagine painting olive drab on that woody in the top right photo. The half track in the 6th picture is off loading raw asbestos for processing.
  24. 29bowtie
    29bowtie
  25. 29bowtie
    29bowtie
    Lots of history in these pics. The bottom left photo must be staged, no man looks at a map! The bottom right is the first car to drive across Canada.
  26. 29bowtie
    29bowtie
    Hopefully nobody minds a few more?
  27. 29bowtie
    29bowtie
    Just about done for tonight.
  28. swi66
    swi66
  29. swi66
    swi66
  30. swi66
    swi66
