Vintage Tach Collectors Show and Tell
Discussion in 'The Hokey Ass Message Board' started by scottrod2, Nov 25, 2007.
    And if you need to check your amperes, use this nice old tool
    rod1 likes this.
  2. Six Ball
    Six Ball
    from Nevada
    This is from a '55 Studebaker Speedster. I finally found a tach sender and hope to use the entire group in my '26 Chevy roadster.
    [​IMG] [​IMG] [​IMG]
    Ric Dean likes this.
  3. ronzmtrwrx
    ronzmtrwrx
    Can anyone date this Sun tach by the style of the font? It's 6v and the print is light green image.jpg
  4. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    My Dixco from '65. Was in my AV8.
  5. Some of the ones I have, the small ones are plastic faced so maybe 60's or early 70's? (Dixco and RAC?). Hmm, seems I don't have a picture of the other tach, but it's the same size as the Dixco at around 2 1/16". tach-1.JPG
  6. 56sedandelivery
    56sedandelivery
    I really like this thread, and the others over the years dealing with tachs/gauges. I recently bought two tachs; one is an original, non-transmitter, 8 grand Sun Super Tach in beautiful condition. A "REAL" Sun Super Tach, not the lame Super Tach II. The other is IDENTICAL to the 8 grand Sun Super Tach, but it is marketed by Equus, a California company still in business today, but manufactured in Taiwan. It's NOS, right down to the box it came in, the warranty card, instruction sheet, and wiring kit. Even the font, blue and white stripes, and pointer, is identical to the Sun's writing, but instead of Sun Super Tach, it says Pro Racing Tach. Talk about counterfeit! I just can't put a date to it. The tach in my 56 Chevrolet Sedan Delivery is an 8 grand, black and white face, Sun, with the short sweep. I'm sure it's been in that car since the 60's. Good thread. I am Butch/56sedandelivery.
  7. tinsled
    tinsled
    Here's an old SW tacho I found some time ago. Unfortunately I do not have the sender unit.
    Where could I found a matching sender - anyone?
    0...3000rpm is low range for a car, but since I installed R10 OD in my D24, I might try to hook this tacho... ;-)
    p.s.
    Anyone would know the age & original apllication where this was used?
  8. c322348
    c322348
    There are two types of senders that will work. One plugs into the distributor tach drive (and is the same as the SW speedometer drive that plugs into the transmission tail-shaft) and the other mounts between the distributor and the distributor cap. The latter are extremely hard to find.
    Look at my album here where I have a copy of the catalog pages for these: http://www.jalopyjournal.com/forum/media/albums/stewart-warner-corporation.43975/
    Yours must have originally been intended for a diesel engine due to the low RPM range (no distributor there obviously).
  9. ROADSTER1927
    ROADSTER1927
    I believe you may be incorrect on a transmission sender for that tach, with the 3 prong plug I think it was only for the distributor unit, and the plugs and bakelite unit for the dist are both very hard to find! Gary P9010008.JPG
  10. Six Ball
    Six Ball
    from Nevada
  11. Hotrodmyk
    Hotrodmyk
    Pretty cool thread. Here are a couple of pics of an old mini tach I have had since the '60's. I believe it is a Dixco but it doesn't say on it. Ran it on a banger for a while. mini_tach1.jpeg mini_tach2.jpeg
  12. I believe it's early-mid '60s. Any red or white numbers on the back of the tach head?
  13. powrshftr
    powrshftr
    Anybody got an idea what year this one was manufactured?
    I just got it back from Williamsons.
    Top notch work,and great folks to deal with!:)
    Scott
  14. powrshftr
    powrshftr
    falcongeorge and Muttley like this.
  15. Dreddybear
    Dreddybear
    Stoked on this one. Needs a little clean up but worth it!
    falcongeorge and Hotrodmyk like this.
  16. ronzmtrwrx
    ronzmtrwrx
    Thanks. It's in a cup, so as soon as I get the chance, I'll pull it out and look for some numbers.
  17. ronzmtrwrx
    ronzmtrwrx
    Model RC. 5A. on tag. Red ink numbers stamped on back: 1357 1
  18. The model number matches that style face. The red ink number are throwing me a bit as you don't see that many numerals, usually. Is that actually a space between the "7" and the "1"?
  19. Mid to late '60s for sure. I've seen similar models from the early '60s, so it maybe earlier as well. Do you have any ink stamped numbers on the back of the tach head?
  20. powrshftr
    powrshftr
    I will have to pull it apart and have a look.
    I still haven't hooked it up yet,but I can't say enough about the amazing work that Williamsons did on this thing.
    Absolutely outstanding!:)
    I'll get back to you when I get it apart for some numbers.
    Scott
  21. ronzmtrwrx
    ronzmtrwrx
    Yes, there is a space there between the 7 and 1. It says on the tag it needs an EB or WB transmitter. It had a EB 1A 6 volt transmitter with it, which I have also. Given the low rpm scale and the 6 volt transmitter, I was guessing early to mid 50s, but that's only a guess.
  22. Your tach is not a style one sees often and, when I answered your original post, I was going on memory as to when I had seen that style. I still think that style, or something like it, was used during the early '60s. There were still 6V vehicles in use during that time, so Sun cud have still produced some of those tachs. However, now that we've looked at the ink stamped numbers on your tach, I'd say that tach was from 1957. That style probably does date back to the early '50s as well, but I just haven't seen enough of them to say for sure.
  23. ronzmtrwrx
    ronzmtrwrx
    Thanks a bunch. As you stated, I have not seen this style of numbers before, either. The idea of 1957 vintage makes sense. It was in the pile of parts in the car in my avatar, and it had had a 265 chevy in it before it was parked in 1961. I'm going back with a flathead, so the 5K scale will be fine
  24. No problem. Glad I cud be of some help to you. Have you tested the meter yet to see if the needle bounces and returns properly?
  25. Old-Soul
    Old-Soul
    I'm gonna bump this thread up as it deserves another go-around and also because I require some input on a tach I picked up years ago.
    It'd a Jones Motrola 5101-213 cable drive 10k tach. I'm under the impression it's late 60's, the fella I bought it from pulled it out of an ex drag tri-5 that he was restoring to run on the streets.
    Curious as to the history and value associated with this piece a I am nearing the point of my coupe build where I need to start selling shit in order to fund new shit :(
    C. John Stutzer likes this.
  26. greaser 35
    greaser 35
    from FRANCE
  27. stewartwarnertach.jpg swtachback.jpg SWtachfront.jpg View attachment 3475717 View attachment 34 ss
    Swapped cheapie $5 swap meet solid state guts into my 760-AT stewart Warner tach tonight...works great and I was able to keep the S.W. face plate and all needles. Didn't notice the orange paint had fallen off one needle until I was all finished...damn!
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    Bowtie Coupe likes this.
