Vintage Tach Collectors Show and Tell
Discussion in 'The Hokey Ass Message Board' started by scottrod2, Nov 25, 2007.
  1. Here is an older Argo tachograph I found. It records info on a chart inside the tach. Used on big trucks. The center of it is a clock.
  2. weim55
    weim55
    Not tryin' to be a smart ass here......really.....
    I sure pretended this was a tach as I went through the "gears" on my Sting Ray. It's the only part I have left from that old bike. My first set of wheels, I was 10 years old....
  3. LIL.TIMMYUser Name
    LIL.TIMMYUser Name
    JEEZUM CROW!!!! is that an honest odometer reading on your stingray speedo?:eek:
  4. johndanger
    johndanger
    My favorite right now.
  5. Muttley
    Muttley
    I have one.
    falcongeorge likes this.
  6. Randy P
    Randy P
    from Austin, TX
    This is an Airguide Scat Tach, anyone know anything about it? It's still in the cardboard display, reads "Helps you really GO", "Accurate, Transistorized, Illuminated". Chrome plastic body and chrome is a little deteriorated. Looks very '60s to me, maybe '70s? I think Airguide made speedos for boats, so maybe it's marine?
  7. yoyodyne
    yoyodyne
    Do you mean this one?
    In this case, Stahl is Stahl and Associates, a speed shop in York PA, Not directly related to Jere Stahl or Stahl headers, who is also located in York. IIRC, ther was a family conntecion, don't remember exactly.
  8. I'll play along...finally got around to doing the install along with some cleaning & polishing;
    Model D-3 tach (only seen 1 other 5k model D tach with the red numerals)
    Model E-2 Transmitter...wiring & connectors are original (with the exception of the engine ground wire)
    Yup, uses a D-cell battery for power.
    Stamping on rear of transmitter...I have been told that this may be a date code...I purchased the tach together with the transmitter as a matched set, stamping on the rear of the tach is "150". Possible manufacture date 1950???
  9. bbc nova
    bbc nova
    from Minnesota
    Hello
    Any idea what this tach is or what it’s from? There is no manufacturer, numbers or identification on it? Any help would be greatly appreciated!!!!!!!
  10. LIL.TIMMYUser Name
    LIL.TIMMYUser Name
    did you pull the rear off? should be some markings inside. some pics of one i recently picked up.
  11. bbc nova
    bbc nova
    from Minnesota
    Still no markings. Id like to sell it but want to get an idea of its value first and what to list it as. Was told it works but havent verified yet.
  12. tommy
    tommy
    66 Chevelle "knee knocker" It mounts under the dash to the right of the steering column. They used to be pretty costly. I believe that different engines used different red lines but I don't know which red line is correct for which engine. Check on some Chevelle sites. It does not need a sending unit. I paid 200 bucks for one to use on my 66 SS396 convertible many years ago. I'm not certain but I think they started to repop them. I found one a couple of years ago real cheap and did pretty well on Ebay.
  13. chryco
    chryco
    from Winnipeg
    My Stewart Warner mechanical tach , from the late sixties , to mid seventies .
    I have a S/W and of the same tach in the Sox and Martin 68 Cuda Super Stocker .
    Chryco
  14. chryco
    chryco
    from Winnipeg
    Here it is ...............
  15. maniac
    maniac
    Heres 2 I have, don't know which sender goes with what tach, don't know if they work either
    [​IMG][​IMG][​IMG][​IMG]
  16. Sloppyseconds
    Sloppyseconds
    from Pasadena
    I got this one from Don montgomery at a swap meet... Ive always loved the DANGER!!
  17. Does this tach take a sender? I just picked up a similar one this weekend. It appears to be date coded 5/63. p/n 810750.
  18. Bump once for info please, before I Pm.
  19. Deuce3wCpe
    Deuce3wCpe
    from New Jersey
    Since this thread is back up I'll run a question....I have always liked the old EELCO "silver faced" gages but have never seen a matching tach or speedo and don't see where they were offered in any of the the old catalogs. Seems kind of crazy that they would produce a complete line of gages and not offer these. Heard a rumor that a couple were spotted at the Pomona swap a few years ago, but they may have been custom made/silk screened.
    Anybody..........?
  20. Any idea of the year of this Dixco ? It's in the henry j I just bought and not sure if it even works since the car has an HEI dist. in it.
  21. Leevon
    Leevon
    from Nixa, MO
  22. MotoArts
    MotoArts
    I'm sure the 5K is a marine unit, but have no idea on the 10K...
    And does it require a sender?
    Anybody know?
    Back side of the 10K:
  23. volksjunky
    volksjunky
    I'm pretty suprised to not see another Moon here,my father gave this to me last summer.I have no idea how old it is.
  24. ROADSTER1927
    ROADSTER1927
    My collection thats not in anything yet. I have one of the 8000 rpm long tachs in my hot rod roadster,that is driven from the dist with an extension under the cap as shown in one picture. Gary :)
  25. memaerobilia
    memaerobilia
    Here are two old oddball tachs. First one is a 3 1/4 inch mechanical Jaeger 0 to 15,000 with the tach drive cable. Second one is a 3 inch General Electric 0-9000 tach from U.S. Navy Aero, in really nice condition.
  26. Fast67VelleN2O
    Fast67VelleN2O
    Actually your Jaeger tachometer does not go up to 15,000. It goes to 1,500 rpm. Your numbers on the tach face get multiplied by 100.
  27. memaerobilia
    memaerobilia
    Thanks for pointing that out..Looked at them too quick, I guess. I was thinking the "X 100" was for each incremental line on the dial. So I guess the other G.E. one (marked in small print on the dial as "100 RPM" only goes to 900 rpm? and must be for something very small & slow? As I said..."oddballs."
  28. yoyodyne
    yoyodyne
    I still have this one. Cable drive Jones Motorola w/telltale.
  29. nybronc
    nybronc
    any of you guys know of a chrome mechanical tach, we are building my sons chevy and would like preferbly a moroso chrome with tell tale if poss.? thanks, newyorkbronc
  30. Halfdozen
    Halfdozen
    Late '60's, early '70's VDO. No sender required, 6 or 12 volt, + or - ground, 4, 6 or 8 cylinder, wrinkle finish aluminum cup, ball and socket mount. Will one day reside on the dash of my '40 Chev coupe with 292 inline 6.
