Vintage Tether Cars
Discussion in 'The Antiquated' started by Ryan, Jul 22, 2008.
  1. rotten ron
    rotten ron
    Lepus it is a Pagco Jet Built by Pagliuso Engineering Glendale Ca.
    EL MOE, lurker mick and Lepus like this.
  2. rotten ron
    rotten ron
    1948 Challenger. One of three cars that used the Challenger name. The one shown here is the first version to use that name. Challenger cars were sold as a pan, rear and front end. There were no wheels, tires or body. A hand carved wooden body was offered by the manufacturer. These bodies were carved by Joe Lig. The car featured a front suspension via two inline coil springs. At $32.50 for a pan, rear end and front axle it was fairly expensive compared to other cars at that time. IMG_3626.JPG IMG_3627.JPG IMG_3628.JPG IMG_3629.JPG IMG_3630.JPG IMG_3631.JPG
  3. Lepus
    Lepus
    The frog finally came in the mail. There is a bunch of lead melted into the front of the belly pan, and a wire ran 007.JPG 008.JPG through the two holes near the rear threaded holes. I think this was a wall hanger, and maybe the lead kept it hanging at a good angle. There is a little lime green paint left on the bottom. I will start working on it after I finish my Thimble Drome Champion.
  4. Lepus
    Lepus
    I will post more in process pictures, but here it is after many hours of filing and sanding to get rid of mold lines, bumps, scratches, and areas where the top and bottom didn't line up. I'm making a new grille, and am planning an 8ball brake lever knob made of black and white delrin, banjo steering wheel, and engine turned dashboard.the exhaust and pressure pump are done after much filing, sanding, polishing, and drilling the end of the exhaust pipe. 005.JPG 006.JPG
    echo ed, Deuces, 35cab and 3 others like this.
  5. rotten ron
    rotten ron
    Lepus TLC will have repo parts you might need. Motor mount, rear tires, ect.
  6. Lepus
    Lepus
    Ron, their website seems to be gone. Is there a new address for them?
  7. rotten ron
    rotten ron
    Lepus Phone number 714 449-2154 web tlctethercar.com Ron
  8. Ron, Gary Arnold gave up his on-line store awhile ago. Best to e-mail him at tlcent1@gmail.com.
    Great guy with a ton of knowledge.
    Mick
    rotten ron likes this.
  9. rotten ron
    rotten ron
    Mick I have not bought from Gary for a year or so thanks for the up date. Ron
  10. Lepus
    Lepus
    Here are come photos of the work on the Thimbledrome Champion. The first is the start of filing and sanding the body halves to match, and to get rid of the mold lines. The second is how i got the paint off the top half.
    The black paint came off very easily with one or two applications of paint stripper. The red on the top barely softened with 4 or 5, so I poured it in a can and left the top in it for a few hours.I still had to do that twice to get 99% of the paint off. The 3rd photo shows the exhaust pipe after I started filing it, to show how the mold lines stand out. 018.JPG 001.JPG 021.JPG
  11. Lepus
    Lepus
    Next, I made the grille. I laid it out with Mastercam, then milled the frame, with slots for the bars to fit into. The bars are .04 brass sheet. o.d.s were turned first, then i.d.s, then I ground a .04 diameter into a lathe tool, and turned the radius on the o.d.s, then sheared them off, and milled them to their various heights. next was soldering, a little filing, then cutting the assembly off the block it was milled from. Then filing to round off the frame some, running a threading die over the lower projection in back, and filing a notch in the upper one, to hook on the opening in the body of the car. Then some polishing and it's done. 008.JPG 004.JPG 005.JPG 006.JPG 007.JPG 009.JPG 015.JPG 019.JPG 035.JPG 036.JPG 037.JPG
  12. rotten ron
    rotten ron
  13. rotten ron
    rotten ron
    Lepus good stuff your grille is super.
  14. Lepus
    Lepus
    b-bop started a thread called "the ultimate shift knob?", with a link to a video of a guy making an 8ball of stainless steel and brass.It's about 2 1/2 inches dia. I think it looks cool,and I thought a miniature (1/4 inch dia.) version for the Thimbledrome would be really cool for a brake lever handle.I made it from black and white Delrin. First I milled 2 round projections in a block of black Delrin,( the 2nd in case I messed up, I wouldn't have to start from the very beginning) drilled a 1/8" hole 1/8" deep, then turned a white plug to press into that. Then I drilled a .050 hole below center in the white plug. then I turned a black piece to about 1/8" dia, then drilled it.040, took it out of the lathe, and turned a white piece to press into the .040 hole in the black piece, which then went back in the lathe, to be turned to .051, to press into the 1/8 dia, white piece.repeat this process for the upper loop, but with .040 and .030 diameters, and the hole cuts through the edge of the lower loop.The walls of the black pieces end up about 5 thousandths of an inch thick, that's why I don't finish the o.d.s until the white pieces are pressed in. Then I drilled and tapped the 2-56 mounting hole. Then I cut it off the block, put it in the lathe, and used a radius tool to make half of it spherical. then mounted it with the tapped hole, and finished turning the rest of it, followed by sanding with 320, 600, then 1500 grit paper. the lever is made of stainless. 023.JPG 025.JPG 027.JPG 029.JPG 031.JPG 032.JPG 033.JPG 001.JPG 004.JPG 005.JPG 006.JPG
    down-the-road, Deuces, 35cab and 5 others like this.
  15. Lepus
    Lepus
    I started on the dash and steering wheel. I really like all the detail of old British tether cars, ( or tethered cars, as they call them) so I'm going to make gauges to go on the engine turned panel. The panel is made of stainless shim stock. I have a spring loaded tool I made, with a 3/8" dia. end with a rubber disk glued to it. for this job, I turned the rubber down to 1/8" dia.. I taped the shim down to a piece of flat stock in my CNC mill's vice. I coated it with lapping compound, (grit in grease) and programmed the mill to drill holes .1 inch apart in a row, then go up .05, and over the same amount, and start the .1 spacing again. The machine thinks it's drilling holes, but it's compressing the spring in the tool .1 inch to push the rubber into the steel, and drag the grit around and create each swirl, 486 times.The steering wheel will be another banjo type. 002.JPG 005.JPG
  16. rotten ron
    rotten ron
    Home built Tiny Tornado. Built to plan from 1940 Popular Science magazine. Constructed by a proficient craftsman. Hardwood frame with a carved wood body and metal hood. Front wheel friction drive. Brown engine and Spin True wheels and tires. Ron
    IMG_3632.JPG IMG_3633.JPG IMG_3634.JPG IMG_3635.JPG IMG_3636.JPG IMG_3637.JPG
  17. rotten ron
    rotten ron
    1939 Synchro Rocket. Among the first manufacturers to offer a complete kit. Came with a steel frame and 10 blocks of wood that the buyer would carve to plans that came included. All drive line parts, wheels and tires all came with the car for a total price of $19. For an additional $14 you could buy an engine made by Synchro Devices. This example has a Dennymite engine and a Dooling rear drive grill fitted to it. Ron
  18. Rick J
    Rick J
    Nice Syncro, Ron.
    Coincidentally, I'm working on one right now. It came to me needing the body finished, and missing any electrical components. Still a bit of work to do, but it's getting there.
  19. rotten ron
    rotten ron
    Rick Looking good. ron
    lurker mick and Rick J like this.
  20. Richard Zimmerli
    Richard Zimmerli
    I'm new to the tether car scene as I was lucky enough to aquire a champion Products car in need of some help with information and sourcing some tires which are falling apart every time it's moved and the belly pan is cracked in a couple places so any info would be greatly appreciated. FB_IMG_1635214271657.jpg FB_IMG_1635214283460.jpg FB_IMG_1635214296463.jpg FB_IMG_1635214314032.jpg FB_IMG_1635214356291.jpg FB_IMG_1635214350402.jpg FB_IMG_1635214337772.jpg FB_IMG_1635214332076.jpg IMG_20211025_131855040.jpg
  21. Lepus
    Lepus
    Richard, a good welder with experience welding cast aluminum could fix your belly pan.Ron or one of the other more experienced guys probably know where you could get some reproduction tires. they got me in touch with a guy who sold me really nice tires for my Dooling Frog.
    Deuces likes this.
  22. Richard Zimmerli
    Richard Zimmerli
    Lepus thanks and I'm a Md. Resident also in the Crofton are.
  23. rotten ron
    rotten ron
    Richard If you need a little info on the repair to you car call me. Ron 805 5867205
  24. Lepus
    Lepus
    I just bought this book today. It is copyrighted 1941, by Popular Science Publishing Co. I guess it's reprints of magazine articles. They are mostly plans and instructions to make furniture, other household stuff,small boats, and home carpentry and metalworking tips. There are a lot of model railroad and plane plans, and one tether car plan.Also, coincidentally, for Richard, I've included an article on repairing cast aluminum.
    lurker mick and lothiandon1940 like this.
  25. Lepus
    Lepus
  26. rotten ron
    rotten ron
    1939 Duesenberg front wheel drive. This car rarely comes up for sale and they are sought after by collectors. Only between 50 and 100 were made. They were made both before and after the war. It is a large car over 21 inches long, and because of their weight they were not very competitive. The Duesenberg came in kit form for $32.50 and fully assembled minus engine for $35. Various engines were used for power. This example has a McCoy 60. It also has the correct Duesenberg wheels fitted with Champion tires. I think these are very good looking tether cars. The aluminum castings are excellent quality and polished they are impressive. Ron IMG_3766.JPG IMG_3767.JPG IMG_3768.JPG IMG_3769.JPG IMG_3770.JPG
  27. Rick J
    Rick J
    You have lucked into a very desirable tether car. I've seen your FB posts and several people wanting to buy it, so you're aware of that fact.
    You will LOWER the value of the car by replacing the tires. If you must fix the pan, do not leave it up to "someone who knows how to weld" aluminum. Send it to a specialist such as Wayne Short. There are others who are tether car experts who can do the work and won't ruin it by accident.
    Obviously, it's your car and you can do whatever you want with it. I'd leave it as is. Find a less rare, less expensive car if you want something to restore or fix up. Just my 2 cents.
    cracked lacquer and rotten ron like this.
  28. Rick J
    Rick J
    Ron, you have the coolest cars!!!
  29. A Boner
    A Boner
    First painted one I’ve seen...except for the one I have! Mine is Navy blue...most were/are just polished aluminum, with the factory paint long gone on the factory painted ones. 6E0E6C52-C079-40A6-BD01-4C64561EF3B8.png
  30. rotten ron
    rotten ron
    Hi A Boner, the Duesenberg came finished 4 different ways. Speedway red, blue, cream, and probably most popular, and the one you see the most, polished. I'm not sure if mine was red originally. It was 80 years ago. Who knows how many times it might have been repainted. Ron
    48fordnut and Deuces like this.
