Projects Vinyl to metal adhesive
Discussion in 'The Hokey Ass Message Board' started by Tom Noller, Dec 31, 2016.
  1. Tom Noller
    Tom Noller
    from Iowa
    Guys - I'm working on the door upholstery on my '54 Kaiser and in the process of re-doing the arm rests. Using vinyl, I'll have to use an adhesive to hold the material in, while dropping the top part back into the plastic shell, since it all has to be tucked in and tight enough to look right.
    What would you recommend? Friends have suggested Gorilla Glue.
  2. HOTRODPRIMER
    HOTRODPRIMER
    3M spray adhesive,spray one surface for a temporary bond,both surfaces for a permanent bond. HRP
  3. KoolKat-57
    KoolKat-57
    from Dublin, OH
    HRP is right on the money, I did armrest over the summer as you described.
    I used the 3M heavy duty spray from one of the crafty stores.
    Worked great, spray both pieces then let them sit for a bit, you may need a heat gun or blow dryer to move the vinyl, start in the center and work out, take your time and I'm sure they will look great!
    KK
  4. 3m Spray adhesive is good stuff, follow the directions and it's an instant bond
  5. Special Ed
    Special Ed
    Professional trim shops use contact cement, very similar to the 3M product previously described.
    prewarcars4me likes this.
  6. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    If you have any upholstery supply shops near you, best, bar none.
  7. K13
    K13
    Yup that's what upholsters always recommend. Spray adhesive can sometimes let go if the interior of the car gets too hot. Every upholster I have ever talked to about adhesives say that the spray ones are use at your own risk.
  8. HOTRODPRIMER
    HOTRODPRIMER
    My pal Dave uses the 3M adhesive on a lot of small parts when he doesn't want to clean his spray gun.
    Most of us don't need a 5 gallon bucket of adhesive or have a spray gun dedicated for spraying glue,especially for a small job.
    Dave does a lot of interiors and to my knowledge doesn't ever have a problem. HRP
  9. Special Ed
    Special Ed
    Just make certain to use the FLAMMABLE product, and heed the warnings on the label. It comes in containers as small as a pint, so it's much less expensive than the aerosol stuff.
    Saxman, stanlow69 and prewarcars4me like this.
  10. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Apply it to both the back of the vinyl and to the metal. Wait until it is tacky, not wet, not dried. Once tacky and you go to put the two together, get it right the FIRST TIME, because there usually isn't a second chance,lol.
    Special Ed likes this.
  11. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    You can buy it in small pint sizes to 5 gallons, and use a BRUSH. The 3m aerosol can come apart in extreme heat. Not uncommon for us to have a few days here every summer over 120 degrees and the landau glue holds up on panels where the 3m comes apart.
  12. Tom Noller
    Tom Noller
    from Iowa
    All super helpful, thank you!
  13. HOTRODPRIMER
    HOTRODPRIMER
    Yeah,I suppose the temperatures are considerably warmer in Arizona than here in South Carolina during the summer. HRP
  14. jcmarz
    jcmarz
    from Chino, Ca
    I used contact cement for my rubber seals on my AD. I bought it at Home Depot and it's in a old fashioned brown gl*** jar.
  15. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    But it's a dry heat. Of course when a chrome seat belt buckle touches your leg, a scar is a scar. I'm sure the 3m will work on most stuff, but extremes test product's limits.
  16. 5window
    5window
    This stuff won't stand up to the temperatures generated inside a closed car in summer, not the unheated garage in winter. Use the Weldwood contact adhesive in the blue can stuff.
  17. 5window
    5window
    This stuff is the bees' knees. I brushed it on, it holds great. I divided it into gl*** quart jars and, after a couple of years, at least one of the jars is still good. You can get it here:
    http://www.yourautotrim.com/noname37.html.
    It's under $30.00, plus shipping and you can usually find a discount code-15% right now. You may not need a gallon, but, honestly, you're really going to save $10-15 bucks by buying spray cans and then have it come apart on you? Who wants to redo any part of an upholstery job for $15.00? Do it right, do it once.
  18. Special Ed
    Special Ed
    Ummmmmmmmmmmmmmm ... this IS the Weldwood stuff. :rolleyes:
  19. 29moonshine
    29moonshine
    there is a difference between the weldwood cement and the wellwood adhesive
  20. Special Ed
    Special Ed
    Yes, there is a large difference between spray and roller grade contact cement. Spray grade will be much thinner to make spraying easier. I would not try thinning roller grade.
  21. FrankenRodz
    FrankenRodz
    I've been using 3M rattle can for close to 20 years.
    77 is a fine spray with medium hold. (Great for most fabrics, where you don't want glue to come through).
    90 is a spatter spray with more aggressive hold. (I'd use this for vinyl to metal contact).
    Walmart has the best price around here, Homer Depot about $1 more per can. Interior Side.JPG Pass. Upshot.JPG DSCN0428.JPG
  22. stanlow69
    stanlow69
    I go threw 10 of these 5 gallon pails a year. The Weldwood cement will work, but not quite as good as the adhesive. It is a little more runny. Takes longer to set up. Your upholsterer is your friend. He will sell you some. Why does everybody have to buy stuff on-line. The contact cement is available at every hardware store and lumberyard.
  23. 5window
    5window
    The two upholsterers I know of in the area are crabby, slow and expensive. They are not amenable to small jobs. I'd rather buy fresh stuff and be sure of the delivery. We are talking $30. here people. 3M 90 spray lists for $12.99 at Home Depot so you'd get 2 cans or 35 ounces for basically $26, or a gallon of Weldwood for 4 dollars more. Guess, as with everything in hot rodding, it's your choice.
  24. stanlow69
    stanlow69
    Not every body is crabby, slow and expensive. Some are helpful. Or try to be.
  25. 5window
    5window
    I, by no means, meant to imply that that are. Just explaining why, in my neighborhood, I am buying this stuff online.
  26. stanlow69
    stanlow69
    The pails I buy have a hazardous materials logo on them. My salesman hides them in his truck incase he were ever was to get pulled over by the DOT. U-Pull-It wouldn`t even take the empty can full of s****-metal. Because of the logo. I just paint the cans now. Because of the logo, they are expensive to ship.
