Projects Visions 2.0 Craigslist Addition
Discussion in 'The Hokey Ass Message Board' started by corncobcoupe, Oct 19, 2025.
  1. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    So, previously if you fellas remember I had visions to create my Pontiac Lemans Super Duty wanna- be that went up in flames.
    So, another project entered my head and lucky that the fellas posting Craigslist Posts here had one that turned up.
    I didn’t buy it, but worked out a trade on an off - topic Mid 90’s GM performance car I had that just didn’t excite me.
    So, the fella I traded with is giving it to his wife who is excited to get it.
    So here it is……55 Buick Special Tudor Sedan.
    Nothing fancy and as you know, I lean towards odd ducks.
    Always thought of them as an old farts car and I guess I'm entering that Twilight Zone part of life.
    WTH... try to make something odd look cool right ?
    264 Nailhead with 3 on the tree.
    Runs , Drives, Stops….. nothing fancy, it's a driver.
    Is an older amateur restoration / amateur paint job that looks ok from 20 feet. I’ll continue an amateur upgrade taking the orbital sander to it, re- spraying it from the current white / blue changing to white/ black. It will match the new black interior put in last year. Definitely the strongest part of the car. Nice seats, carpet, door panels, package tray, headliner.
    May heat the front coils to drop it an inch or two. May just tire rake it to start.
    I really don't want to tear the front suspension apart if I don't have to. Lazy huh ?
    I’ll leave the rear the same height as is a Delco double hydraulic shock set up. I just want to rake it forward down a little bit.
    I haven’t decided on the wheel and tire I want to run.
    Carb needs a kit. It has a dead spot I need to look at further. It has the rare carb that you press on the gas pedal to start it,
    no key- only a switch flip and push down on the gas pedal to start it up. So purchasing a remanufactured one to unbolt/ bolt is that rare earth material unobtainium.
    Love this era of car for its dash panel is cool.
    Chrome is fair at best, a bump here and there. Trunk is solid. Drivers floor has a patch. Mileage is 79,902 and I’m leaning towards it’s legit / not spun over.
    The first pic was right off the trailer dirty.
    The rest of the pics after giving the old girl time to get her hair and nails done at the car wash.
    . IMG_4888.jpeg IMG_4895.jpeg IMG_4894.jpeg IMG_4904.jpeg IMG_4907.jpeg IMG_4908.jpeg IMG_4906.jpeg IMG_4905.jpeg IMG_4891.jpeg
  2. 57 Fargo
    57 Fargo
    That’s a killer car to cruise
    porkshop and alanp561 like this.
  3. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
  4. tubman
    tubman
    If that Buick is like almost every other car with coil springs up front, do yourself a favor and cut them, don' heat them.
    Perhaps the ever popular Aerostar springs may fit; they seem to work on everything else.
    porkshop likes this.
  5. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Remember I mentioned the Carb, issue with a dead spot or maybe a ****erfly shaft play and being a rare carb that starts by the gas pedal.
    I found this below by @Brad54 from his HAMB post 19 years ago….answers my questions on options.
    “Bad thing about the early Buicks is that the starter circuit runs through a switch on the base of the carb. That's why when you flip the ignition on and then mat the gas pedal, the engine fires up.
    You'll either have to completely rewire the ignition system, wire a push ****on starter into or ????, or find yourself a stock 4bbl carb from a '54-'56 Buick.
    There is a difference in those carbs, as well--the body on some of the years is taller than the '54 (don't remember the specifics). That will be an issue only if you plan on using the stock air cleaner ***embly.”
  6. deathrowdave
    deathrowdave
    from NKy
  7. Squablow
    Squablow
    What is that rocker/lower quarter panel trim? Never saw that before.
    I know it's not a democracy, but some Olds Fiesta flippers on there with wide whitewalls, a bit lower in front, maybe exhaust cutouts, and removal of what appears to be black window tint film, would make a very nice looking car out of this. A careful cut and buff on that paint probably wouldn't hurt, either.
    Interior looks to be in nice shape, and a stick is a huge bonus in one of these, very rare and very desirable considering the Dynaflow's reputation for running slow and leaking fast.
    dwollam and Moriarity like this.
  8. SS327
    SS327
    Just don’t burn this one up like you did that poor Pontiac. :D
  9. Yup, needs wheels, yup needs rake, yup oozes cool.
  10. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Don't know on the rocker and quarter trim. Looks really good though and stainless.
    I have a set of Fiesta's that I tried one yesterday and determined it's a little bent so I have to find one.
    Definitely looks better with Fiesta's. ( Everything looks better with Fiesta's....all time fav for hub caps.)
    dwollam, Squablow and Moriarity like this.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, nose down, nose and deck it, shaved handles and emblems. needs loud duals, already has the required 3rd pedal and hand shaker... cool man....
    porkshop, dwollam and 57 Fargo like this.
  12. Lone Star Mopar
    Lone Star Mopar
    Looks cool from where Im sitting. Mark has the right ideas for a cool simple cruiser !
  13. 325w
    325w
    Nice as is!
  14. LOST ANGEL
    LOST ANGEL
  15. BJR
    BJR
    I had that same motor in a 54 Special. I put a 4bbl from a 55 Super on it and what a difference it made. Felt like I put a bigger motor in it. Also don't heat the springs, I cut 1 1/2 coils on mine and it looked great.
    skooch likes this.
  16. dirt car
    dirt car
    from nebraska
    Nice Buick & a plus it happens to be a stick shift as finding parts & someone familiar with the automatic at a reasonable price can be an issue.
  17. guthriesmith
    guthriesmith
  18. 19Eddy30
    19Eddy30
    from VA
    down-the-road and SS327 like this.
  19. CSPIDY
    CSPIDY
  20. Crocodile
    Crocodile
    Looks like a ton of fun!
  21. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
  22. ClayMart
    ClayMart
    "She's a beauty, Clark!" ;)
  23. stuart in mn
    stuart in mn
    Neat car, it's unusual to find one with a manual transmission.
    It is kind of a sharp turn from a Super Duty Lemans, though. :)
    I know they have a lot of sharp pointy bits that aren't safe in an accident, but 1950s dashboards were so cool.
    SS327 likes this.
  24. manyolcars
    manyolcars
  25. Move the necker's knob to the left side of the steering wheel!
    Otherwise you can't use it when shifting.....and other things!
  26. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Took it off for now.....
    It will go back on the left, if I put it back on.
  27. southerncad
    southerncad
    What BJR said, put a 4 BBL on it and it will really wake up the motor!
  28. catdad49
    catdad49
    Black and White, 2150 Bye!
  29. 38Chevy454
    38Chevy454
    Not knowing the exact late model you traded for the Buick, I would have to say a good trade in my view. It has all of the basics for a nice cruiser with some simple changes.
