Technical Viton or PTFE Valve Stem Seals?
Discussion in 'The Hokey Ass Message Board' started by jaw22w, Jan 27, 2025.
  1. jaw22w
    jaw22w
    from Indiana
    I'm ordering valve stem seals for my SBC. I see seals made from Viton and some from PTFE. Is there an application where you would use one but not the other. What is the application for each? I have been using Viton, but I couldn't give you a reason why. Just curious what the difference is!
    I guess I am particularly concerned with the heat of the exhaust valve.
    Any insight?
  2. jimmy six
    jimmy six
    I currently use only Viton seal material VTO small OD seal. They are metal to metal at the valve guides. All my guides are cut to .500” to be the same on all engines, stockers or racing. I cut them myself with a Comp Cams tool. I purchase them from Compe***ion Products.
    Years ago I used the Teflon but changed for some un remembered reason. I’m sure they will work just as well. I still have them in my Bonneville travel box.
    jaw22w likes this.
  3. jaw22w
    jaw22w
    from Indiana
    I used those small OD valve seals on my .531" guides. They are a ***** to get off. I had to get destructive to remove them. My dual springs don't require them so I'm going with the larger OD seals with the Viton all the way down this time. They are much easier to remove. Do you have a trick for removing the metal clad seals easily?
  4. jimmy six
    jimmy six
    I wedge them off with a fairly large screw diver. I chuck them anyway. My reason: After 2 races with a new set of Dart Cast Iron heads ***embled by a shop with excellent parts I removed the rocker covers and found red plastic appearing pieces. 1/2 of the seals were inside the springs and we removed the pan and found red pieces on the oil pump pick up. Luckily I had the tooling to remove everything on the head still on the engine. It is a single spring head because we run a flat tappet cam by the track rules at #140 psi. I felt the spring movement did damage but the smaller diameter metal to metal was a better choice.
    jaw22w likes this.
  5. 302GMC
    302GMC
    from Idaho
    If you're forced to burn ethanol laced gas, AERA recommends sticking with .002 stem to guide clearance & just o-ring seals if the engine will not be in constant use.
    jaw22w and Fordors like this.
  6. seb fontana
    seb fontana
    from ct
    How bout some different seal pics? I'm ready.
    jaw22w likes this.
  7. 1biggun
    1biggun
    If there is room I ran the umbrella seals like a ford uses that does not grip the guide .
    Otherwise I was still running the Teflon seals as I have a bunch form years ago .
    I like a little lube on a stockish street engine so I like the umbrella or just the factory oring in the retainer like chevy did for the last 65 years or so .
    jaw22w likes this.
  8. Dedsoto
    Dedsoto
    from Australia
    Viton seals are more forgiving if you're a little heavy handed on installation. Teflon seals work well but can crack or chip easily.
    jaw22w likes this.
