Volare clip advice?
Discussion in 'Off Topic Hot Rods & Customs' started by RamSST, Sep 27, 2008.
  1. RamSST
    RamSST
    So I'm looking at buying a older(85ish) dodge diplomat to fix my 84 ramchargers engine issues(motor swap-the 84 has finished off it's cam, timing chain, and the heads have given up and it has 50 psi of compression on the two back cylinders.) but I'm also looking at buying a 54 dodge regent to have as my cl***ic cruiser. I've checked it out and the width of the FMJ(volare, diplomats, etc had the same width) has the same width as the front of the 54. So I figured I'd strip the diplomat of all useable parts for the 54. So i was thinking maybe somebody might know or have some advice on how a guy would go about putting a volare clip under the 54? I'm thinking that as I want this done for winter(I'm going to end up giving the fiance the ramcharger for her winter driver and I would drive the 54) I'll put the volare clip under the 54's factory frame and make up a set of brackets that will bolt it to the car(will be professionally installed by pipefitters from my work) I'll also use the diplomats rear axle and install it with it's height according to how high the front ends up. I have a 79 dodge slant 6 and I'll steal the 904 auto from the 68 dart project in my garage for the car(both are good pieces that are in good shape) and I'll also use the driveshaft from the dart because the 904 and the driveshaft will be useless as a Viper V10 with a 6 speed will replace the stock slant auto combo.
    So thats kind of the plan I want an old car to tool around with and I figure with the friends I have(I know a guy who has worked on tons of old cars) that I can have the car likely done as a roller in about 2 weeks and running in 3. Just not sure if my plans on the volare clip and the way i want to install it are plausible because of the limited info on the 50's dodge's
  2. mbmopar
    mbmopar
    from Canada
    Tex Smith's book How to build hot rods and how to build hot rod trucks has info on installing these torsion bar front ends.....i may still swap one into my 55 Dodge 1/2 ton, but we'll see how the factory design works for now : )
    Derek
  3. pool
    pool
    I'll second the book by Tex, I believe the worst problem people have is the frame clearance(or lack of) around the steering box. I would also check on ball joint and bushing availability.
  4. barney rubble
    barney rubble
    I don't know much about the 85's but the older K-members were different fron V-8 to 6 cyl on the mounts. You could not use one for the other.
  5. 41woodie
    41woodie
    I ran one in a 64 Ford pickup that I owned for awhile. Did not like it at all, ride was pretty harsh. I didn't do the install so I don't know if it could have been improved by a better install, also it was pretty close to the bottom of it's travel to lower the ride height which probably didn't help. But based on my experience I wouldn't have another.
  6. twofosho
    twofosho
    Various bushing durometers by application, but one size fits all as far as torsion bar size would explain ride height and suspension harshness problems in a non stock installation. Using the T-bar as the strut rod also was also found to be not such a great (think bad) idea.
    I too, like to use everything I can when I kick something in the head, but in this case I have to think there are far better solutions out there.
    If you like the idea of the adjustable ride and lower unsprung weight that torsion bars provide, some of the later (73+) rubber isolated longitudinal T-bar front ends, with the exception of the rear torsion bar anchor crossmember, had everything attached to the K member including the upper control arms. And although most people shy away from them, if you can do a successful frame graft, a stout enough rear crossmember to mount torsion bar anchors should be child's play. The fact that the Chrysler longitudinal T-bar suspensions from 1960 on had some of the best geometries to come out of Detroit doesn't hurt either (compare their specs to contemporary GM F and A bodies of the time and you'll get the idea) and can still hold their own when equipped with modern shocks and bushings.
  7. George
    George
    For clarity it's Tex Smith's Chr, Dodge,Plymouth Hot rod book, not the generic How to build Real Hot Rods book that has a Magnum to a 53 pick up article in it
  8. Kustomkarma
    Kustomkarma
    Dodge Aspen, Diplomat, Plymouth Volare, and older LeBaron (I believe) all have the same front suspension. The widths should be the same. The K-members are different between the six and the eight engines. Check these guys out if you need to go that route.
    www.engine-swaps.com/frames/frame_73upABFMJmount.html
  9. terrarodder
    terrarodder
    from EASTERN PA
    I've benn running a Volare front clip in my 37 Terraplane Street Rod for 14 years. Never had any problums with it, nice ride, good handling. I also use a K-car power R&P steering.
  10. I've done many Volare units on several vehicles. I did one on a 52 Dodge because the Owner insisted on it all being Chrysler. The combination ****ed! The coil spring sockets were a major blister. I ended up building a pair of frame rails out of 2"X3" tubing to make things go together. Never Again on a early Chrysler! I currently have a friend doing a S-10 on his Dodge SW. It's going together much nicer. If it rides and steers well, it would be the better choice. His car is not done yet so the Jury is still out. What ever you do don't M-2 your car.
    The Wizzard
  11. DrJ
    DrJ
    Too old and worn out.
    They won't lay frame either without putting them on the bumperstops.
    Ya might look at Jag sedan (XJS?) for a more modern solution. easy(er) instllation too.
  12. George
    George
    Coil springs?:confused:
  13. His 54 Dodge has Coil springs, Not the Volare.
  14. T McG
    T McG
    from Phoenix
    Most Volare swaps end up incorrect with no alignment possibilties. You need a flat surface to mount them to which most 50s style frames don't have. The 53-56 Ford F-100s have a fairly flat frame bottom which is why that was a popular swap for many years. The last I knew, the main torsion bar to frame bushings weren't available. And remember, most pipe fitters are just that, not car builders. If they don't understand suspension geometry, you will have an empty pocket and an ill handling disappointing ride.
  15. 50dodge4x4
    50dodge4x4
    I think a 1st or 2nd gen Dakota frame would be a much better way to go. If you use anything other then the original suspension you are probably going to have to do some pretty hefty modifications on your original frame. Expect that. Gene
  16. From the way this sounds it seem like the volare clip would be a poor choice for my 51 F-1. That ****s, I have one sitting in my garage ready to go under the frame.
  17. brewsir
    brewsir
    Wrong...we put one under a F1 a couple of years ago ...it sits right and drives extremely nice.......it's not really that hard on a truck because the frames are pretty flat and straight since they had leafs up front. The F1 will require a notch in the siderail where the steering box sits and some clearancing up front for the torsion bar adjusters....but so what! Get Tiny on here to take a few pictures for you of his setup.
  18. okiedokie
    okiedokie
    from Ok
    Or go to ford-trucks.com and look at the suspension tech threads, great info there. I have a Volare under my 53 F100 and am very pleased with it. Rides and handles well. My only complaint with the Volare is the size and location of the crossmember, it really makes it tight under the front of the engine compartment. But it was relatively easy to install, cheap to aquire, although I did go completely thru it with new stuff. I like it fine. Joe
  19. RamSST
    RamSST
    I'm thinking the stock frame may be my best option. I like the coil spring setup. Maybe next year I'll 4 link the rear and air bag the ch***is.
  20. I drive one of those 140 miles a day to work and back, best riding car I ever had. I'd use it if it fits. Keep the 318 too, why use the six?
  21. nvr2lo
    nvr2lo
    I have 58 f 100 with a volare front clip, from what ford car can I get the axles from for my ford nine inch. Right now they are 5 on 5 bolt pattern with 28 spline shaft. Thanks :eek::eek::eek::eek:
  22. dart4forte
    dart4forte
    from Mesa, AZ
    Back in the late 90s local salvage yards were buying up Volares just for the front clip. I remember seeing dozens sitting on pallets
