Technical Volcanization question
Discussion in 'The Hokey Ass Message Board' started by SteveClary, Oct 22, 2020.
  1. SteveClary
    SteveClary
    Does anyone know how to permanently attach a white three inch wide, 1/8" rubber strip to the sidewall of 235/75R15 radial?
    Specifically what bonding agent and what type of rubber would be most compatible with the composition of a sidewall of a modern radial tire?
    Are there any cold cement options that get close to the heat processes commonly used?
    If you're in the Fort Worth area and would be interested in this DIY experiment shoot me a line.
  2. lothiandon1940
    lothiandon1940
    I think you mean Vulcanization.
    LOU WELLS, catdad49, wraymen and 4 others like this.
  3. SteveClary
    SteveClary
  4. Gofannon
    Gofannon
  5. scrap metal 48
    scrap metal 48
    I don't think it will work.. At least it didn't work for me many many years ago.. The porta wall will wrinkle up after a very short time.. I think you're better off painting them or buying white lettered tires and spinning the tire to grind the black off for a nice, fairly wide real whitewall.. Just my take on it....
    lothiandon1940 and VANDENPLAS like this.
  6. egads
    egads
    Easiest and best way would be call Diamondback. :):):D
    VANDENPLAS and scrap metal 48 like this.
  7. SteveClary
    SteveClary
    Thanks Gofannon. I will research that bonding agent.
    Does anyone else know how to permanently attach a white three inch wide, 1/8" rubber strip to the sidewall of 235/75R15 radial?
  8. HOTRODPRIMER
    HOTRODPRIMER
    It's not something you can do in your garage, what I have posted is in layman's terms. HRP
    Vulcanization is a chemical process in which the rubber is heated with sulphur, accelerator and activator at 140–160°C. The process involves the formation of cross-links between long rubber molecules so as to achieve improved elasticity, resilience, tensile strength, viscosity, hardness and weather resistance.
    VANDENPLAS and Truckdoctor Andy like this.
  9. bchctybob
    bchctybob
    Any chance you could get thinner white rubber like say 1/16”? It may conform to the sidewall better and not resist the contortions of the sidewall in motion - less load on the adhesive joint. I would try the contact cement used for inner tube patches.
    You might research vulcanizing patches and how they worked but putting even pressure and heat on a whole sidewall will require a m***ive fixture that will definitely make the whole deal not remotely cost effective.
    VANDENPLAS likes this.
  10. Budget36
    Budget36
    Maybe try a Chem site?
  11. bchctybob
    bchctybob
    BTW, I’m going to experiment with a couple of the spray-on methods mentioned in your other thread. Never hurts to have options.
  12. BJR
    BJR
    Just buy white walls, the other **** just doesn't work.
    scotty t, egads and Pist-n-Broke like this.
  13. SteveClary
    SteveClary
    Yes... thank you for that....
  14. wraymen
    wraymen
    Groundhog Day, sorry but it’s been done. Bill Murray finally figures it out towards the end if the movie.
  15. Lone Star Mopar
    Lone Star Mopar
    Replied on the other one.. Ive thought a modern urethane based adhesive like they use to glue wood floors down with might work for this exact thing. Its flexible but still strong as heck and sticks to anything. Would be easy enough to try.
  16. Jalopy Joker
    Jalopy Joker
    if tires are white walls find a old school shop that can shave/grind black off to expose more white - paint 'em - remember,tires heat up and expand/contract - glue alone will not work
  17. grumpy65
    grumpy65
  18. SteveClary
    SteveClary
    Thank you Lone Star Mopar. I will research that bonding agent.
    Lone Star Mopar likes this.
  19. Many many years ago I actually worked in a Tire Recaping shop. Back in those days there was an actual process to add Whitwalls. Once you understand just how much a Tire flexes you'll understand why you can't just Glue on a white piece of rubber. Not to mention the Temp changes they are exposed to.
  20. SteveClary
    SteveClary
  21. grumpy65
    grumpy65
    ^^^ "People Who Say It Cannot Be Done Should Not Interrupt Those Who Are Doing It"
    People who say it cannot be done sometimes actually know what they are talking about, and people who ask for expertise and guidance should sometimes humble themselves and be a little more receptive. :rolleyes::rolleyes::rolleyes:
    34 GAZ, VANDENPLAS, RMONTY and 2 others like this.
  22. chrisp
    chrisp
    There are companies who vulcanize white rubber to tires, but not all brands of tires because on some of them the black bleeds through the white rubber and it has to be brand new tires.
    Everything else has been tried by other people and every time it leads to the same failures, yet some people are willing to try the same things hopping for different results.
    Jalopy Joker and egads like this.
  23. Jeez Mate, you’ve asked your question, ignore the answers you don’t like and appreciate the answers you do like!! Why poke the bears? You started out so well, then,,,,
    You get more bees with honey than vinegar,,, constructive criticism.
    wraymen and VANDENPLAS like this.
  24. SteveClary
    SteveClary
  25. AldeanFan
    AldeanFan
    I worked in a tire shop so I know a little about tires.
    What you’re asking cannot be done DIY.
    Pist-n-Broke likes this.
  26. Well, at least your being polite and neutral this time around.
    If it where me, I would check with a retread shop and see what they say and what products they use or can recommend.
    Like I said in your last thread , you won’t find someone to do this.
    But you may find someone in the industry who can point you down the right road.
    try the tire patch companies like prima etc, they might now what glues and rubbers will work for what your thinking of doing.
    If what your planning works and is cost effective enough it’s a good idea.
    I would want to speak to industry experts in n something like this cause quite easily you can make a mess and be out a decent amount of money.
    good luck !
  27. chopolds
    chopolds
    from howell, nj
    Quit trying to reinvent the wheel, or in this case, the whitewall tire.
    I think in the 70+ years that very creative, inventive, smart guys have been improving cars, building rods and customs, someone would have figured this out. Cali White walls tried it, and their method winds up with brown walls.
  28. RMR&C
    RMR&C
    from NW Montana
    Shoe Goo.......that **** will stick to anything!
  29. SteveClary
    SteveClary
