Voltage Regulator Adjustments for 8V
Discussion in 'The Hokey Ass Message Board' started by blowby, Nov 4, 2013.
  1. blowby
    blowby
    from Nicasio Ca
    My truck came with a fairly fresh 8V battery which I'd like to use at least until it ****s out. But I have a 6v Delco 3 unit regulator (generator system), so it doesn't keep the battery up. Is it feasible to adjust the regulator to charge at a higher rate?
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    Yes,but the best results will come from having someone who knows how to do it do it. If you wish to try it yourself get a Motors manual and read up on the way to do it.
  3. d2_willys
    d2_willys
    from Kansas
    Adjust only the voltage regulator contacts, not the current or cutout.
  4. I've hooked up a meter , and then bent the tabs that the springs are hooked to. I believe I did the voltage , and the cutout , don't have to go much , and with the meter hooked to the 'batt post , you will get there , BUT, If you are not comfortable with wiring . Get someone who is familiar with regulated systems , still a few of them around , If you do something wrong , or short something , it WILL burn those tiny wires .
  5. blowby
    blowby
    from Nicasio Ca
    Thanks guys. I hooked up a voltmeter to the bat terminal, was showing about 7.5v. I bent the spring mounting tab down on the voltage coil only and now it's about 8.7v. Hopefully it will do the trick.
