Voltage Regulator Clicking
Discussion in 'The Hokey Ass Message Board' started by flashback, Feb 12, 2013.
  1. flashback
    flashback
    I have a 1950 ford f1 pickup that was chaged to 12 volts. The bearings in the generator that was installed had gone bad so I replaced with rebuilt generator. Before replacement the voltage regulator started clicking.
    Now with new generator the regulator is still clicking. The clicking is from the voltage limiter at the "ARM" conection.
    Is there a way to adjust the voltage regulator to stop the clicking?
  2. oddcraig
    oddcraig
    From memory I think the clicking is actually normal for voltage regulators.
    You could try replace it with a solid state one and see if that helps (if it isn't one already).
  3. HOTRODPRIMER
    HOTRODPRIMER
    Do you have the voltage regulator grounded? HRP
  4. flashback
    flashback
    Yes with the firewall and an extra wire grounded.
  5. flashback
    flashback
    It there a Solid State Voltage Regulator that could be used with the 12 volt generator?
  6. Mr48chev
    I don't believe there is. The "clicking" is the points in the regulator opening and closing and that is normal. They don't "regulate" if the points don't open and close when they need to.
  7. 1971BB427
    1971BB427
    from Oregon
    They should click as they regulate, but if they are clicking too fast there's a problem in the system. I've seen them really chatter if the voltage isn't adjusted properly.
  8. fatheroz
    fatheroz
    Try 'polarizing' the generator. The most common way is to remove the wire from the "F" terminal on the regulator and touch it briefly to the "B" terminal. It'll spark. Then put the wire back where it belongs. This is another forum discussing this issue. And about five different ways of doing it.
