Technical Voltage regulator question
Discussion in 'The Hokey Ass Message Board' started by Domesticsonly, Sep 10, 2021.
  1. Domesticsonly
    Domesticsonly
    This may be a dumb question, but I want to mount the voltage regulator on my firewall. This car will not have a hood and I live in Florida---Will there be any issues (short or long-term) if the regulator gets wet?
  2. FrozenMerc
    FrozenMerc
    Soldier all wire connections, and use weather tight connectors, and you should be fine.
  3. Bob Lowry
    Bob Lowry
    I don't suspect anything major. They normally have a cover and a gasket with 2 screws to keep them pretty
    moisture-free inside the cover. On the backside there are some open elements that I have seen corrode slightly
    over time even in a covered engine compartment. Bob
  4. jimmy six
    jimmy six
    I’d stay out of salt water rain:rolleyes:. I’d say there have been 100,000 to 500,000 hood less hot rods built and run with open generators and even alternators and a million miles in the rain. Many of us look for an overp*** when caught out. Water can not get under a tight ring style connection.
    I’d carry a small can of WD-40. It’s the proper use of it. WD = water displacement.
