Hot Rods Volts to distributor
Discussion in 'The Hokey Ass Message Board' started by dalerobin, Dec 31, 2014.
  1. dalerobin
    dalerobin
    I have a 1979 chevy motor Im puting in my 1946 plymouth. Converting car to 12 volts. The chevy didtributor has a built in coil with two connections. May I go directly to the didtributor with 12 volts or must I reduce the voltage and if so is the drop to 9 volts ?
  2. Yep HEIs run on 12 volts.
  3. King ford
    King ford
    from 08302
    The one marked bat. Gets switched (on and off ) 12 volts
  4. stimpy
    stimpy
  5. dalerobin
    dalerobin
    OK thanks guys.. Other terminal is marked for tack...
