Projects Voyage of the "Dawn Treader"
Discussion in 'Traditional Hot Rods' started by InstantT, Oct 17, 2016.
  1. InstantT
    InstantT
    from SoCal
    I picked up a set of the F2 brakes on Instagram a bit ago based on the tip from neilswheels.
    Just picked up this entire front end from a 56 f1 for $75 from 1oldtimer sending me an offerup post. The guy lived 3 blocks away from me!!!!
    Sent from my SM-A505U using The H.A.M.B. mobile app
    504640 and Hombre like this.
  2. InstantT
    InstantT
    from SoCal
    I'm gonna re-read the link from neilswheels and then see if I can source parts easily enough. If they're on rockauto, I think the big brakes are the ticket. We'll see.
    Outback likes this.
  3. Those look clean, a rebuilt kit for the wheel cylinders, clean up the drums, new bearings/seal and your in business.
    Here's the F100 brake tech week article.
    https://www.jalopyjournal.com/forum/threads/brakes-f100-brakes-on-37-to-48-ford-spindles.5877/
    There are 2 wheel seals for this conversion and everything I read only talked about 1. You need to measure the seal hub on the spindle, 1 1/2" is the National 450461 (in all the articles), if it's 1 9/16" then you need a National 473441. If you have the wrong seal it won't go on the last 1/4" or so, you can force it but it drags bad and will most likely waste your seal.
    InstantT likes this.
  4. InstantT
    InstantT
    from SoCal
    My cousin has 2 40 lincoln zephyrs. One is a ragtop with a Yblock!!
    He didn't have any spare brakes, though.
    I DO have a set of Airheart disk brakes, but they won't be practical for street use.
    I saved my banjo for a 27 T coupe that my dad has. We'll see if I ever get to it.
  5. InstantT
    InstantT
    from SoCal
    Next door George is on my ***. Final mounted the motor. Headers are getting built! 20201220_135910.jpeg 20201220_135926.jpeg
    Outback, Tim, guitarguy and 4 others like this.
  6. joel
    joel
    How are you using those tapered tubes? Are you building 4 into 1 lakester style? It looks like they're heading for the opening in the inner fender and outside the frame.
    Outback and InstantT like this.
  7. InstantT
    InstantT
    from SoCal
    Exactly! Most of the tube gets cutoff down to about 2 3/4 which I'll tap down to a 2.5" pipe that goes down under the running board.
  8. InstantT
    InstantT
    from SoCal
    joel, guitarguy and 40ragtopdown like this.
  9. neilswheels
    neilswheels
    from England
    Wow, look at all that room in there for headers, wish i'd had that luxury, making equal length long tube headers didnt help tho.
    Looking forward to seeing how yours turn out
    InstantT, dualquads and joel like this.
  10. InstantT
    InstantT
    from SoCal
    Mine will be equal length, too!
    Hombre and guitarguy like this.
  11. joel
    joel
    They're better than iron manifold and no steering box clearance issues; Win-Win, I'd say.
    InstantT and 48fordnut like this.
  12. InstantT
    InstantT
    from SoCal
    I thought so. Neighbor George and Evel Jake were making headway on them yesterday while I tried to organize and clean for bigger surfboards and more skateboards after Christmas.
  13. InstantT
    InstantT
    from SoCal
    A brakleen can gave up it's ghost to plug the exhaust crossover. 20210103_212002.jpeg
    Outback and LAROKE like this.
  14. InstantT
    InstantT
    from SoCal
    The left bank head has a ******ed thread I need to address.
    joel, 40ragtopdown and LAROKE like this.
  15. InstantT
    InstantT
    from SoCal
    Outback, LAROKE and 40LUV like this.
  16. InstantT
    InstantT
    from SoCal
    Finally finished the headers and the pipes. Got a trick up my sleeve for the outlets.
    Haven’t been on here in a while after switching phones, but I think I’m back.
  17. neilswheels
    neilswheels
    from England
    looking good..
  18. InstantT
    InstantT
    from SoCal
    So I think I decided to go with the F2 brake setup. I wanted to source generic replacement buick drums since I don’t care about fins and I found iron replacements on RockAuto. Payday tomorrow and I went back on and they’re gone!
    And Buick guys out there that know where to get stock replacement drums?
  19. InstantT
    InstantT
    from SoCal
    I crossed the buick drums to be the same as all pre 72 Pontiac dimensions (other than bolt pattern) and am having trouble even finding those listed at NAPA or Oreilly!
    Do BOP owners usually have this much trouble getting drums? I found a set for 66 GTO on Rock
  20. InstantT
    InstantT
    from SoCal
    Was waiting for the app to work again‍♂️. Next door George knocked out my coil bracket for me and the boy wanted to ***ist in a few repairs to threads. 6260079C-CDFF-4480-B99E-DA5BF1821B15.jpeg D06E2564-EA46-4220-ADDE-89BF0FE2DFA7.jpeg 0C6862A0-7904-459A-85ED-A10347008E5C.jpeg A4AF1901-741D-4CE7-A0D2-A510812026C4.jpeg
  21. InstantT
    InstantT
    from SoCal
    I have done a bit since my last update. Fuel line is finished and the rest of the exhaust is nearly done except for the tips. Decided on 56 F100 brakes and they are on there now 856ECD00-F8A1-4FE5-9FFC-DAF25E919D20.jpeg
    Outback, LAROKE, guitarguy and 2 others like this.
  22. guitarguy
    guitarguy
    Is that fuel line crushed flat on the bend?
    I love how the exhaust exits.
    Outback likes this.
  23. Hillbilly Werewolf
    Hillbilly Werewolf
    Looks great!
    You did a nice job dressing up the SBC, looks right at home!
  24. InstantT
    InstantT
    from SoCal
    No. Looks like that though. It twists a bit, but has plenty of flow
  25. Outback
    Outback
    from NE Vic
    Have just read right through, lovely car & I like the way you are approaching it!
    F2 brakes, are they 12x2"?
    Will subscribe & follow along!
  26. InstantT
    InstantT
    from SoCal
    Yes. 12X2.5" to make full use of the buick drum surface
    I learned about it here from neilswheels. He linked an article on this thread somewhere. I bought the loaded backing plates and started looking for replacement Buick drums (just iron replacemnets that I could modify). I found NOBODY seems to make replacement drums for Buicks. I didn't care about the fins or that stuff since it's a fendered car. I then started trying to find replacement parts for the F2 brakes and found, while available, they aren't what I would call "readily" available. After picking up a set of Buick drums I realized I was in as deep as just buying a set of Lincoln brakes from Speedway brand new. I had the F1 setup and all the parts were about $100 total, and since my 58 F100 stopped just fine, and I'm using a booster, I threw up my hands and went with those.
    I still have the other setup in case I change my mind later.
    Outback likes this.
  27. Dan Hay
    Dan Hay
    Lookin' good man! Keep plugging away. Love the name! We're reading the Chronicles of Narnia with the kids.
    Also, been tinkering with this 39 I picked up last year.
    InstantT, LAROKE and Outback like this.
  28. Outback
    Outback
    from NE Vic
    Lovely Sedan! We have just about finished The Chronicles of Narnia with our Kids too.
    InstantT and Dan Hay like this.
