VW Wheel Center Diameter
Discussion in 'Off Topic Hot Rods & Customs' started by lake_harley, Jan 18, 2026.
  1. lake_harley
    lake_harley
    Does anyone happen to know what diameter wheel center would be needed to make a really narrow front wheel using a VW wheel rim? The thought would be to end up with a 3 1/2"-ish width wheel with a 5 X 4 3/4" bolt pattern.
    Lynn
  2. AccurateMike
    AccurateMike
    These guys have blank 15x3's with a 13.23" ID and 15x4's with a 12.49" ID. AG wheels, no "safety beads". I'm using 15x4's & 15x5's to build some rims myself.
    https://www.heywheel.com/page11.html
    lake_harley and RodStRace like this.
  3. lake_harley
    lake_harley
    That's great info. Thanks!
    Lynn
  4. tim troutman
    tim troutman
    I had a pair saved they would not work with early ford centers
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Been a long time since I made narrow rally’s. This much I do remember. Not all VW hoops have the same ID dimensions. So pick your hoops carefully.
  6. The VW ones I used for mock up on the Studebaker were 4" wide and fit later Ford (outside bump) and Dodge if I remember correctly. The Stude is 5 on 4.5" BP.
  7. jimmy six
    jimmy six
    Miller tire also sell outer rims. I’ve used them for narrow Bonneville tires!
    lake_harley likes this.
  8. lake_harley
    lake_harley
    Thanks for the posts. I see the thread has been moved. I guess because I mentioned VW wheel rims?
    Lynn
  9. deathrowdave
    deathrowdave
    from NKy
    I built many sets from space saver hoops , take a look into them also
    ronzmtrwrx and RodStRace like this.
  10. lake_harley
    lake_harley
    Where is the Miller tire you're referring to? A quick search brought up several. If they have a website it would be great if you could post a link to it. Thank you.
    Lynn
  11. RodStRace
    RodStRace
  12. jimmy six
    jimmy six
    The Miller Tire brings it up first for me. It’s m.e. Miller tire listing for farm and lawn tractors plus vintage implement tires….
  13. I did the opposite, I used the VW center and welded on an Audi hoop to give me a wider rear wheel for a Manx clone I was building at one time.
    That being said, hit a wreckers (if you have any around) and take a look at SpaceSaver spare wheels, they'll give you a skinny/narrow hoop that may work better with your GM (or whatever) centers.
  14. SS327
    SS327
    Be careful though, some of the newer cars the space saver spares have aluminum rims. You can’t even replace the tires on those. They bend too easy.
    borntoloze likes this.
