Hot Rods WAAAY TOO LOUD!
Discussion in 'The Hokey Ass Message Board' started by Sting Ray, May 12, 2021.
  1. lippy
    lippy
    from Ks
    19eddy30, that's what I was thinking, the Borla dragster mufflers. Lippy
  2. lippy
    lippy
    from Ks
    Or 4 inch snuff or nots. A 4 inch washer will quiet it down. Just drill a hole in each side of the pipe, stick a bolt all the way through and weld a washer on the bolt then you can open and close it. Lippy
    loudbang and 19Eddy30 like this.
  3. 19Eddy30
    19Eddy30
    from VA
  4. sdluck
    sdluck
    slayer likes this.
  5. BadgeZ28
    BadgeZ28
    from Oregon
    I put a Dr Gas X pipe on my 55 Chevy. Their claim was you could reduce the exit pipe size quite a bit without restricting flow. You might contact them about your application. Lots of good options at 3" diameter
    https://www.drgas.com/
  6. VOETOM
    VOETOM
    from MO
    Tell me how much room you have, maybe we can build some that work and fit.
    Are they going to be in the stock location? Rear?
    Sting Ray and Blues4U like this.
  7. jimmy six
    jimmy six
    Hard to believe you have 4” exhaust starting at the header flange but Truckpipes.com have 4” inserts and if it is actually 3-1/2” before the muffler Patriot sells augers and I’ve used them.
    Blues4U likes this.
  8. Blues4U
    Blues4U
    from So Cal
    I was thinking about the auger baffles as well, but I don't see them in 4", so didn't post them. If 3.5" that would work.
  9. Jalopy Joker
    Jalopy Joker
  10. squirrel
    you never go racing, so that makes the easy way out, not feasible....
    I have a car that has been in the 9s, similar period to your car, also blown, but I take it drag racing, and don't really worry about how fast it is on the street. When I race, I remove the full out the back 2.5" exhaust system, which has nice quiet "cadillac" mufflers, and run the 3.5" collectors open. When I drive on the street, it's really quiet with those smallish pipes, tailpipes, and big mufflers.
    Too bad you can't do something like that.
    And it just ain't gonna be quiet until you figure out how to put tailpipes on it.
    AHotRod, bchctybob and triumph 1 like this.
  11. Jim - do you have a manufacturer on the Caddy mufflers?
    The 4” exhaust came on the car when I got it. I’m not opposed to going to a smaller dia. Thought I’d see if it was workable but that looks like a slim chance.
  12. 1934coupe
    1934coupe
    I'm tired of noise, my ears are ringing and I'm over 70 with no need to impress anyone. My SS Borla's just came in yesterday (made in USA) from Jegs. I want to listen to the stereo in my 57.
    Pat
  13. squirrel
  14. squirrel
    yes, I looked, that's the right number. And 2.5" tail pipes are not too difficult to find room for...depending on your suspension, of course.
    AHotRod likes this.
  15. seb fontana
    seb fontana
    from ct
    Muffler from Chrysler mid 60's. 2.5 x 2.5, from single exhaust mid to late 60's big mopars.I think. Mounted at collector, run under rear axle and mounted with quick pull pins at rear of frame. 6 bolts, 2 pin and on the ground. Tail pipes and all.. Big A 21682.
  16. Matt55folife
    Matt55folife
    Very cool car but just one question! You have built a blown 440 a/fx g***er and want it quiet?!?!? Come on man! Let that ***** talk!!!! Not gonna be much toneing that thing down.
  17. Speed Gems
    Speed Gems
    Turn down the idle and the car won't be so loud. :D
