Projects Walker special track T build
Discussion in 'Traditional Hot Rods' started by Barillaro Speed Emporium, Feb 14, 2014.
  1. Thanks for all the comments glad you guys are enjoying this build as much as I am! Wanna thank my brother Jim and friends roger and Gary for the help today ImageUploadedByH.A.M.B.1404007379.322364.jpg ImageUploadedByH.A.M.B.1404007403.761053.jpg ImageUploadedByH.A.M.B.1404007422.865889.jpg ImageUploadedByH.A.M.B.1404007439.755858.jpg
  2. sota
    sota
    Looks like you guys kick *** yesterday! Great work as always from the Barillaro Speed Emporium!
  3. Thanks Ed hopefully I'll be callin ya for some bodywork help in a week or so!!
  4. sota
    sota
    I'm ready when ever you are!
  5. old round fart
    old round fart
    from Norman Ok.
    Are you sure about the horizontal watts link? Seems to me when the rear end goes up, both arms get shorter in effect. Can you take off the spring and double check it? If it works it would solve a lot of space problems.
  6. I've checked by bouncing and unloading the suspension the only part that limits it is the amount of the movement in the rod end if I used over centering washers it would move more. The amount of travel that I need it won't be an issue if your using this set up on something with a lot of travel this will limit it. Surprisingly the center pivot doesn't move much at the travel that this car will see.
  7. old round fart
    old round fart
    from Norman Ok.
    O.K. It is cool if it works good just I have never seen a link used like that and I have been doing this a long time. Thanks for the reply. John
  8. ImageUploadedByH.A.M.B.1404355987.680622.jpg ImageUploadedByH.A.M.B.1404356017.358616.jpg ImageUploadedByH.A.M.B.1404356032.092185.jpg . A few shots I got the radiator and track nose mounted. Still have to rebuild the top tank on the radiator and build a grill
    sko_ford likes this.
  9. 55willys
    55willys
    Nice work! makes me want to get back on the 26' modified my friend and I are building. Jim
  10. King ford
    King ford
    from 08302
    Very nice can't wait for paint!...really an inspiration for my dream- future build.....on the watts link I think what blows people's minds is the center pivot being horizontal , but all it does is allow the lateral rods gain and loose effective length......it doesn't matter what plane it's inand the rod ends having thier axis horizontal allows unen***bered vertical motion.......well done
  11. Thanks man I've done vertical watts links and have seen horizontal ones and thought this project deserved one thanks for the compliments!
  12. ImageUploadedByH.A.M.B.1404522013.951751.jpg ImageUploadedByH.A.M.B.1404522040.280906.jpg ImageUploadedByH.A.M.B.1404522061.892993.jpg ImageUploadedByH.A.M.B.1404522099.737240.jpg ImageUploadedByH.A.M.B.1404522119.500542.jpg .
    Made the grill insert today almost done with it I have to come up with a way to mount it and finish welding the bars in and polish it up
    nostalgia59 and sko_ford like this.
  13. sota
    sota
    WOW!!!!Looks great!
  14. Thanks Ed
  15. ImageUploadedByH.A.M.B.1405004742.186815.jpg ImageUploadedByH.A.M.B.1405004758.596341.jpg ImageUploadedByH.A.M.B.1405004771.076817.jpg ImageUploadedByH.A.M.B.1405004782.379961.jpg ImageUploadedByH.A.M.B.1405004794.680194.jpg ImageUploadedByH.A.M.B.1405004805.930629.jpg ImageUploadedByH.A.M.B.1405004815.193985.jpg . With some help from my brother and our buddy Gary the headlights are mounted and we started pulling it apart for finish work and paint
  16. OFT
    OFT
    Outstanding build up!!. Like the rear watts linkage setup and the track nose/grille.
    Earl
  17. hugh m
    hugh m
    from ct.
    The whole car is very nice, but the grille is especially so.
  18. fab32
    fab32
    What a super little hot rod. That thing is going to be more fun than should be allowed. If if were mine I couldn't wait to get it out where you could get it sideways under power and raise some dust.
    kidcampbell71 likes this.
  19. Atwater Mike
    Atwater Mike
    Well planned, notice you didn't have to go back and cut anything major...(or anything I saw)
    Nose is cleverly pieced, cowl skin work surprised me at first. Gave good access to everything under, without having to re-hang sheet metal 4 times...
    Is the grille surround and teeth stainless? (and did you tig them? Great work!)
  20. gnichols
    gnichols
    from Tampa, FL
    Waiting for updates is like being water-boarded! Amazing work. Gary
  21. greazy john
    greazy john
    looks great a lot more done since i last looked it over.... keep up the good work,mizerville john
  22. Thanks the cowl top was pretty beat up so a new piece solved some body work and rust repair. The grille is all aluminum and tiged
  23. Flipper
    Flipper
    from Kentucky
    Very cool little car!
  24. ImageUploadedByH.A.M.B.1405519838.943832.jpg ImageUploadedByH.A.M.B.1405519863.419483.jpg ImageUploadedByH.A.M.B.1405519876.912578.jpg ImageUploadedByH.A.M.B.1405519891.391343.jpg ImageUploadedByH.A.M.B.1405519910.049785.jpg lots of welding and finish work goin on modified my radiator top tank and bottom tank I'll post more of it when it's welded up hard to work on customer work when this stuff is staring at me to get done!!
  25. ImageUploadedByH.A.M.B.1405701924.784085.jpg ImageUploadedByH.A.M.B.1405701940.700391.jpg ImageUploadedByH.A.M.B.1405701966.351002.jpg ImageUploadedByH.A.M.B.1405701979.173303.jpg ImageUploadedByH.A.M.B.1405701993.934440.jpg
    More progress body in primer and built the headers now I can yank the v860 and finish welding the ch***is. Gotta thank my brother Jim and my buds Gary and Ed for the extra hands and help so we can get this thing done and try to get it to TROG
  26. ImageUploadedByH.A.M.B.1405702401.253449.jpg ImageUploadedByH.A.M.B.1405702416.225060.jpg ImageUploadedByH.A.M.B.1405702433.649932.jpg
  27. sota
    sota
    Looks good Mike
  28. Thanks Ed
