Wanna see my crack?
Discussion in 'The Hokey Ass Message Board' started by 48stude, Nov 29, 2009.
  1. 48stude
    48stude
    I picked up this 66' 327 for the heads for free. But, other than this freeze crack , the block is in good shape. I would like to use it if I could. I'm wondering if this crack could be ground out and welded without worrying about affecting the water circulation and overheating problems? I have a line on another small journal block , but it will need to be bored. Thanks , Bill
  2. grease and ink garage
    i think it can be done !!
    but i would grind it not to far but make a weld over it and not grind that !
    make sure you heat it up properly before welding !
    sorry for my ****ty english ! :D
  3. Hyway Hauler
    Hyway Hauler
    You know, these blocks are not that hard to come by, and for cheap too. I would ditch it, and have I have done so on other sbc's...but thats what I would do...you can do whatever you want to do.
  4. Jimv
    Jimv
    If it won't get in the way grind it clean & build the weld up!! drill holes at each end of the crack & use a cast iron welding rod.Should be OK, not too critical of a spot.BUT Make sure the cylinder wall isn't cracked also!! That happens alot of times when a "freeze" occurs.
    Don''t worry about how "smooth" it looks after its welded.
    Jimv
  5. Jimv
    Jimv
    Down here there not that easy to come by either.I'd definately try to save it.
    JimV
  6. american opel
    american opel
    from ohio
    i agree.if it was a super rare block i think it would be able to be welded.if you just want to get a car on the road fast and cheep then weld it.the worst that happens it leaks.
  7. american opel
    american opel
    from ohio
    i have used jb weld on a cracked aluminum block before{oil would poor out}it worked for severel years.i sold it and the guy that got it off me as far as i know is still driveing it.
  8. grease and ink garage
    thats great stuf but i can get it no more over here :(
    fixt the crankcase of my old bike with it !
  9. I think the jb weld is a much better idea , peen the block mostly back and grind and fill with JB
    The welding keeps pulling and you start chasing cracks all over the place
  10. american opel
    american opel
    from ohio
    there are a bunch of diff.kinds.im sure you could get so off ebay though.
  11. MarkzRodz
    MarkzRodz
    I've seen 'em fixed many times just like that then deck the surface.
    Speaking of old,,, I had some stuff in a can my Great Aunt gave me,,called "Smooth On". It was in a small yellow can and it was really heavy as it had a (water based) hardener and it was mostly fine cast iron. I imagine some old timers here remember it. Anyway the instructions simply was to mix it with water and bump it into the crack several times in a row with a hammer. I've always seen where it was considered proper to heat the block really hot like in a small oven several hours.First, grind the crack out into a slight "V" down to pretty metal,,then weld.Then back in the oven to cool very slowly.
    Oh,,I almost forgot,,when I used Smooth On as directions said too,,it worked every time on different blocks.Same crack as in the thread's picture.
  12. LowKat
    LowKat
    It can be repaired but if the block needs machining (bored) I'd find a different one before spending money on machine work
  13. lippy
    lippy
    from Ks
    As was said earlier, you can weld it yourself. I had a 396 block that was cracked from the freeze plug hole out about a couple inches. I ground out the crack..vee'd it out, drilled a small hole at the end of it, got some high nickle arc welding rod and welded about an inch then stopped and let it cool a little, then finished welded it. Peened it with a slag hammer, and ran it!! The nickle rod takes a bit more heat than regular steel rod to weld but it is strong. I also have welded a lot of cast iron old gas engine water hoppers back together with it. Hope this helps. Oh yeah, as was said, I'd deck it after your done. Happy welding. Lippy:D
  14. RichFox
    RichFox
    I just had the Morton & Brett head welded on. It surprised me that welding Cast Iron seems to no longer be the big deal it once was. Like these guys are saying, High Nickle rod made for iron and short welds. Bang it moderitly to see if it's stuck before going on to the next short weld. Seems to work well.
  15. lippy
    lippy
    from Ks
    Rich, remember when the only way to do it was preheat it good, and braze it with a torch and the old flux in a can deal? Depending on how good the cast material was, it could be a nice job, or a disaster!:p
  16. 55 dude
    55 dude
    x2::D
  17. Spity
    Spity
    Drill out the ends, and start drilling and taping and plugging the whole length of the crack. Someones got to have a link of this, I tried google.
  18. 55 dude
    55 dude
    that method is standard navy fix and works great! the guys at the lemay museum use that method on big$$ vehicles.
  19. shawnspeed
    shawnspeed
    from Attica Mi
    It's called lock s***ch, and it looks like what you need
  20. onlychevrolets
    onlychevrolets
    I repaired a 400 SBC that was cracked in that same way. Worked just fine...
  21. Mr48chev
    As a couple of the guys said, stop drill the ends of the crack, Vee it out a bit and use high nickle rod. The guys I know who do it on a regular basis preheat the block as they feel that gives a better weld. I'd take a real close at the cylinder walls in that area especially right at the wear ridge though as I have seen similar blocks crack right in that area under similar cir***stances.
  22. tommy
    tommy
    It looks like an easy weld to me. Out where it is easy to get to. Back in the 60s a buddy had a 57 block that was welded on the side like that. It held up well to street racing. He had one of the first gl*** tilt front ends on his 55. He'd tilt it up and show the potential compe***ion (****er) the weld and no side motor mounts. Of course you could not see the stroker crank inside.:D
  23. 440shawn
    440shawn
    Used J.b. Weld year ago on a crack in a big block Chrysler. Worked great with no leaks.
  24. Any of the weld methods talked about,br*** with a torch or preheated and welded with Nickel Rod should work fine. Stop drilling is a must. I like to put cast Iron parts in an oven at 400 degrees for a few hours once prepared for welding before I start the actuall welding operation. This is a two fold deal as it not only preheats the object but it also burns out any oil impurities that contaminate the weld. Do NoT try this in your Wife's oven !! As mentioned check the ALL cylinder bores carefully but should there be any cracks, all is not lost. Any cylinders that are cracked can be sleeved and the block decked. YES, Expensive and Time consuming but looking at your location I would say you may have to repair what you have.
  25. plym49
    plym49
    from Earth
    As several have stated, this is a textbook crack for s***ching. THis is where you drill a hole, tap it, thread in a plug, get it flush to the block, drill another hole that overlaps the first plug, and repeat until done.
    You can do it with regular hardware but for best results you can get a kit with tapered taps and tapered plugs.
    This is a very common repair, it has stood the test of time. It does not require skilled labor (like properly welding cast iron) and only common hand tools.
    If you s***ch that block it will last 1000 more years.
  26. May Pop
    May Pop
    I second stop drill the ends and braze. I have done this before and it works.
    Ron
  27. gimpyshotrods
    gimpyshotrods
    I now have had a few successful cast Iron repairs! I stop drilled, vee'd and used nickel rod. I pre-heated two propane weed burners on opposing sides of the part, and ran them until the whole thing was over 400. After welding, I post-heated, turning the burners down a little at a time, over one hour, and then let the parts cool the rest of the way in still air. Not hard, but it does take some time.
  28. A long time ago, on this site, someone posted about using a TIG, but on A/C (as with Aluminium). I have not tried this, but it does make some sense as the penetration might just be better.
    Preheating and drilling a hole to stop further cracking are two good pretexts to the actual welding.
    Cosmo
  29. captainjunk#2
    captainjunk#2
    drill an 1/8 th inch hole at each end of the crack to stop it where it is , then grind a vee on the crack heat it with a torch and weld it with some 55 hi nickel rod 1" at a time lightly peen it with your welding hammer for roughly to minutes to take the stress out should be good to go , its in a decent spot the one on my straight 8 is tougher to get ,
