Technical Want to go with higher Gearing (FOUND 'EM THANKS!)
Discussion in 'The Hokey Ass Message Board' started by "Wally", Nov 9, 2020.
  1. "Wally"
    "Wally"
    Currently running 2.75 gears in our '27 Roadster Land Speed car with a Ford 9". Looking to go to 2.49 or 2.50. Had another 1k in rpm in her but was pushing boost to the limit (15lbs). Going to change pulley on blower as well to slow it down a little. Set a new record in D/BGRMR at 173.429 (181 top speed) but pretty sure we can get to the 190's with taller gears. Any help finding is appreciated. Also have a "Wanted" ad in classifieds. THANKS!
  2. jimmy six
    jimmy six
    Post it on landracing.com Probably have a call in 10 minutes.
  3. "Wally"
    "Wally"
  4. big duece
    big duece
    from kansas
  5. gimpyshotrods
    gimpyshotrods
    If you don't find what you need on Landracing.com, let me know. I think that I have a rear with 2.50:1 gears in storage.
    I also happen to be moving things out of storage, to my new shop, all this week. I will see if it is still in there, and still good.
    i.rant and wraymen like this.
  6. "Wally"
    "Wally"
    That be great! if you come across it let me know, I definitely appreciate it!
  7. Elcohaulic
    Elcohaulic
    Do you run a standard rear end or do you run limited slip. I would think limited slip would be more weight and right were you don't want it..
  8. big duece
    big duece
    from kansas
    Then run a spool...
  9. "Wally"
    "Wally"
    It has a standard rear end. Direct to a turbo 400 no drive shaft.
    Elcohaulic likes this.
  10. Mike51Merc
    Mike51Merc
    They'll be much better on the interstate....:D
  11. Charlietruck62
    Charlietruck62
    Look under 1977 to 1979 ford thunderbirds and cougars with the 351 engine.
  12. Boneyard51
    Boneyard51
    Let me check, I have about ten sets of take out nine inch gears stored. Might take me a day to get to them.
    Bones
  13. "Wally"
    "Wally"
    That's fine Bones, much appreciated, car's not going anywhere at the moment! Don't have any snow tires for her. :)
  14. Going from memory, the tallest Ford gears are 2.50 and 2.47. As said look under late 70's cars when emissions were strangling and before OD trans came out.
    porknbeaner likes this.
  15. oldsman41
    oldsman41
    Did you post on racing junk.com
  16. Boneyard51
    Boneyard51
    Sorry, Wally , I went and checked the seven sets of 9 inch gears I have , started at 5.14, closest I could get to your needs was 3:60.
    Bones
  17. gene-koning
    gene-koning
    Back on the late 70s up to the mid 80s Chrysler put out a lot of 2:45 geared 8 1/4 rear axles, mostly under the mid sized cars and the light duty 1/2 ton pickups. They are not as stout as a 9", but for what your using it for, it would work great. An 8 1/4 Chrysler rear axle doesn't have a lot of power robbing drag in them. One time I bought a 78 Dodge Charger with a 400 motor and was very disappointed to find a 2:45 geared 8 1/4 under it!
    I just sent a complete 8 1/4 with 2:45 gear axle assembly to the scrap yard a couple weeks ago that was in a truck project I'd bought. Gene
  18. "Wally"
    "Wally"
    Thanks for checking Bones.
    Boneyard51 likes this.
  19. mgtstumpy
    mgtstumpy
    If I recall I picked up a 2.5:1 9" years ago from a Galaxie that was being parted out. OEM gears if memory serves me correctly. I swapped out the gears.
  20. 2.47 came in a Lincoln late 70's I got one from Flat Top Bob about 8-10 yrs ago.
  21. patterg2003
    patterg2003
  22. lippy
    lippy
    from Ks
    Swap to an automatic with OD? maybe? Lippy
  23. Stan Back
    Stan Back
    Let's rebuild the whole rear end for him. Or just help him find a "punkin" change.
    All Bonneville roadsters are different. Ours took me on a sight-seeing tour during a once-ever change to a positraction.
    jimmy six and Boneyard51 like this.
  24. Boneyard51
    Boneyard51
    I’m looking, have a friend that has six nine inch rear ends, he’s looking at the ratios, now. Heck, those 2.47 used to be all over the place! Lol
    Bones
  25. "Wally"
    "Wally"
    Lot's of information Boy's I appreciate it. Got a couple of leads I'm pursuing but keep the info flowing. Switching from current 2.75 to 2.47 at 6000 rpm, with everything else the same, is going to take us just under 200mph! 6300rpm and we are at 204mph! Pushed 6200rpm this year and the engine was REALLY happy, 7000 Red Line.
  26. "Wally"
    "Wally"
    Thanks Bones, yea I think everyone threw 'em in the scrap bin.
  27. gimpyshotrods
    gimpyshotrods
    I hope to have my car axle on the bench this weekend. Fingers crossed.
  28. "Wally"
    "Wally"
    Crossed on both hands! Talk soon
  29. Boneyard51
    Boneyard51
    Well he ain’t getting back to me for some reason! Will try to contact him again!
    Bones
  30. dwollam
    dwollam
    Gene, I have an A body 8 1/4" 2.45 rear end. Those gears will only work in that housing and that housing will only accept 2.45 gears. It came in a 318 4 speed Dart I bought (not original to that car). Man, those tall gears made the clutch stink, even in reverse! I robbed an axle out of it to replace a bent one in a 4.11 posi 8 1/4.
    Dave
