WHAT I NEED FROM A 1954 FORD IS THE SHIFT LEVER WITH THE PLASTIC HANDLE, THE TURN SIGNAL HOUSING, THE SHIFT ROD WHICH GOES DOWN THE COLUMN WITH THE TWO LEVERS AT THE END AND THE TUBE WHICH ENCLOSES THE STEERING GEAR ROD. I ALSO NEED THE TWO SHIFT RODS WHICH GO FROM THE LEVERS TO THE TRANSMISSION AS THE 1953'S I BOUGHT ARE PROBABLY DIFFERENT. FROM THE '54'S. I DON'T NEED ANY OF THE STEERING GEAR PARTS. ONE OF YOU GUYS WHO SWITCHED OUT YOUR ORIGINAL 3 SPEED COLUMN FOR A MODERN FLOOR SHIFTER MUST SURELY HAVE WHAT I NEED. THANKS IN ADVANCE FOR THE HELP.
Looks like another member can supply me with all of the 3 speed shift linkage EXCEPT for the two rods that connect the arms at the base of the column to the transmission so I am still looking for those. Alan
Alan, I would have gladly given you the parts from our wagon but I donated them to a fellow '54 Ford Club of America member when we were in Memphis for the convention.
